I understand that oil must be removed from the compressed air used by the Plasma Arc Cutter. In my situation I have an air compressor with an oil injector that keeps my various compressed air tools oiled. My Everlast PowerPro 256 came with an air filter. So what are my choices?
1) Use my compressed air as is because the air filter that came with my PowerPro 256 will clean it up.
2) Put my oil injector on a valve and turn it off when I'm using the plasma arc cutter (I'm not sure my oil injector has an on/off switch).
3)Forget about using my compressed air system because it's contaminated.
4) ???
Thank you!
