Results 1 to 11 of 11
Thread: Question about power cord lenght
  1. Default Question about power cord lenght
    I was wondering what the max lenght is for the power cord before I have to worry about a drop in amps. My shop is 24' by 24' and I couldnt say that Ill be in just one place welding. The attached cord looks to be roughly 6'. How much longer can I run a 220 extension cord?
    Northern Tool sells a real nice 25ft cord they say is good for 50A. It is 8 AWG and has 6-50 NEMA plugs molded on. They sell it for ~$99. I don't think you could buy the parts for that much. US Code does list 6 AWG for 50A.
    http://projectoldwing.com
    wruehl@hotmail.com
    Active Ironbutt Member.
    I too was thinking about replacing the original power cord on my PP256 with something larger and longer, but didn't want to create a warranty issue. So I made this extension cord. I know it will incur the wrath of some of our electrician members or be a "Trip Hazard", but I like to use stuff I have on hand. I saved this 30' length of type SE, XHHW CDRS 3 #6awg from our kitchen remodel. That XHHW is tuff stuff. The only cost was the male and female plugs and a square box. I haven't used it yet, but since my welder outlet is at the end of my shop, by the big doors, this would allow to reach past the center area and outside also. The yellow wire, 12awg XHHW, is for the High Frequency ground connection. Yes I know, by another thread, bigger would be better.
    Tony
    Everlast PowerPro 256
    AC225 "Tombstone"
    HF 20 ton press
    Rotary 9000# two-post
    Hammered, Mike made some good points and I'm guessing you will be fine with 10 AWG since your distance is relatively short - though it is hard to tell without knowing the welders current draw.
    dirtyfarmer, your cord looks good to me especially since the ground connection internal to the welder is chassis mounted, so the combination of the 6 AWG and 12 AWG should make a more than adequate HF ground.
    __________________________
    Everlast Power I-MIG 200
    Everlast PowerUltra 205P
    Everlast SM 200-N
    Thermal Dynamics Cutmaster 42
    Quote Originally Posted by kenwhite View Post
    I just thought there might be some NEC taboo about a portable extension cord made from SE cable instead of SO or SOW or the like.
    Tony
    AC225 "Tombstone"
    HF 20 ton press
    I know I'm not going to win any awards from the Underwriter's Laboratory for this either, but I bought a 25' 12GA extension cord, cut off the ends off of it, and spliced it permanently onto the end of my Super200P's power cable. I recall 12GA was at least as large (I think might have even been one step up in thickness) than the conductors in the machine's original cable.
    I made the splice by prepping the ends of the conductors in a "staggered" manner, to add some insurance they will never directly touch each other. I soldered them together, and slipped some shrink wrap tubing over the connections. Then I slipped a tight-fitting length of extra extension cable jacket material over the entire spliced joint, overlapping each ends, and secured it with small zipties. It was a tight fit, but it might even be slightly waterproof, or at least water resistant.
    This is not as nice as having a continuous length of cable all the way, but I figure its better than having a 30 amp plug/receptable in the middle to have to drag around and possibly trip over. I figured I'd rather have a neat, tidy splice so I could still coil up the wire and handle it easily.
    Apr 2011
    Sasktachewan, Canada
    For my stick welder I just got longer cables. Is that not possible with these machines?
    Attitude Determines Altitude
    If your going to put a long cord on your machine at least take the cover off and make your connections inside the machine (no splices in the middle). Just a pet peve of mine.... and L&I... OSHA... NEC. I've been on a job site where contractors have been fined for electrical tape on there damaged tool cords rather than replacing them.
    James Swanson
    Millermatic 135
    (saving for a Power pro 256)
    Linde HDA200
    Custom water cooler and cart
  1. PA 300 extension cord question.
    By plumber in forum Stick Welding (SMAW)
    Last Post: 10-06-2013, 03:36 PM
  2. power cord
    By travis in forum General Welder Questions
    Last Post: 02-11-2013, 01:26 PM
  3. PP256 power cord ?
    By zoama in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 08-03-2011, 05:36 AM
  4. Supercut 50P power cord
    By rchavez101 in forum Everlast Plasma Cutters (PAC)
    Last Post: 10-15-2010, 06:34 PM
  5. Power Tig 250EX Power Cord Connections
    Last Post: 01-31-2010, 07:58 PM
