Thread: PP256 Setup Guide
    Default PP256 Setup Guide
    All,
    I am trying to put together a setup guide that I can follow when I need to use my PP256. In case someone has done this before, and is willing to share, please let me know .
    First I am trying to sort out which settings work in the different modes. Some things are pretty apparent, such as AC freq/balance should do nothing in DC mode. However, other settings are not so clear. For instance, I was reading a thread the other day that said Up Slope works in PAC mode, which I really would not have expected.
    I've put together a quick chart, and I was hoping that someone could help me correct it. Take a look at the attached pic, and let me know what doesn't look right. I guessed at a lot of these.
    Mike
    Smaw should work in DC with only the DC and amp control. Pulse and AC/AC features shouldn't work (IF it does its not a problem, just means they've done some rewiring to give some unique features). Every thing should work in TIG, but not all work with the foot pedal, some may need to be turned off. PAC should only have DC, post flow and amps.
    Talking
    Thanks, Mark. I've updated the chart. Regarding TIG settings and the pedal, I suspect that up/down slope and start/end amps are the features that would need to be turned off, since they would be controlled by the pedal.
    So, in AC SMAW is the frequency and EN/EP balance normally fixed?
    Mike
    Man, it would be great if some of those features did work in SMAW. I can't wait to try out arc force when stick welding light material.
    The pulse does not work in 2T correct? I've never seen it make any difference when I'm on the peddle.
    Everlast PP256
    Smith Oxy/Acetylene torch
    Atlas 10-F QC54 Lathe
    Seig X2 Mill modified for CNC
    Yes it works in 2T. What are your settings?
  1. 205 pro setup help ??
    By braveops in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 01-06-2013, 05:09 PM
  2. PowerTig 225 LX Alu Setup
    By Biggermens in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 04-09-2012, 08:02 PM
  3. PP 205 Setup and getting started.
    By qcksnake in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 12-30-2011, 02:40 AM
  4. Tell us about your OXY/ACETYLENE setup!
    Last Post: 05-02-2011, 10:48 PM
  5. New CT520D Setup Help
    By poooorsche in forum Everlast Plasma Cutters (PAC)
    Last Post: 06-05-2009, 10:31 PM
