Indeed; I feel the same way, and I hope everyone is OK. This is not an isolated occurrence:
Originally Posted by
robsthomson
The regulator body had a hairline crack running between the gauge and cylinder ports.
jakeru
One of my Everlast flowmeters also had a hairline crack in the main regulator body
SimpleSimon
I just discovered a similar leak on my regulator. A hairline crack from the tank inlet port to the gauge.
jas329
I heard it leaking quite a bit. ... when I looked down on the body of the regulator I saw a hairline crack.
sross
Tried to set up my new 256 and found the same crack everyone else is talking about
djcheetah
I too have a hairline crack to the gauge and the argon is rushing out through the bypass too.
