Results 1 to 3 of 3
Thread: powercool coolant
    Dec 2011
    I live in northeast Iowa
    Default powercool coolant
    hello fellow welders!! I just bought the 250ex and the powercool cooler. does anybody know what the recommended coolant should be? I am currently using rv antifreeze.
    RV af is cool. You can also use distilled water as long as it is not allowed to freeze. The water may grow algae or other gunk, so you might have to change it out every so often. Also possible is using the somewhat expensive coolant marketed for tig coolers.
    Go to wallchart and get RV antifreeze it is distilled water with low freeze point much cheaper than the welding shop
    will take 2 gal with som left over by the time the line fill. This stuff is safe to drink so if it get on you will not harm you
  1. Coolant causing sputtering torch
    By Chevelle69 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 03-08-2015, 01:40 AM
  2. New Manual for PowerCool 300
    Last Post: 01-23-2013, 04:02 AM
  3. Tig Cooler Coolant ?
    By Salty in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 11-05-2012, 11:31 AM
  4. cooler coolant?
    By jdt1986 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 07-22-2011, 10:37 PM
  5. Coolant question
    By Rivets in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 05-04-2011, 02:47 PM
