I have search for a filler rod holder that was 18" with no luck. I found some at my local welding shop that said 18" on them but after measuring, they were only 15 1/2" long.
I got tired of looking and I like to tinker so I thought I would make my own.
I started with a 10' piece of 3" PVC, 5 end caps, 5 test caps and 10 hooks to mount on the wall. I cut the PVC into five 19" pieces, I always cut my 36" filler rods in half so this will give me just enough room so I don't hit the rods with the cap. Next I went to the belt sander and sanded the end that the cap will go on so that it is slightly smaller just so the cap will go on and off easily. Then I pushed the test caps on the other end. You can see in pic#3 that I screwed the test caps on. I didn't want them popping out and I didn't want to glue them permanently incase I ever need to take it apart!?! Ya never know! Next I just mounted the hooks on the wall leaving enough space between them so the 3" PVC will fit. Now just add filler rods, caps and label the outside of the PVC and your done!
I was originally going to paint these white to cover the labeling that is always on PVC. I ended up using Acetone and cleaning the labeling off so I just left them as they are.
I've got $55.16 in parts so it wasn't a freebie but it works perfect for what I wanted and it's another thing I can say "I did it" to!
1
2
3
4
5
6
7
8
