I was curious whether you liked the plate load arm vs say an EZ curl bar. I like EZ curls a lot, but I guess you could build the EZ hand grip into that design. I guess the benefit of that kind of design is you can increase your weight side lever arm so you can do more with less plates.
I can't tell from your notes, are you going to use a bearing in the pivot?
