Results 1 to 6 of 6
Thread: Start amp knob?
    Default Start amp knob?
    If I turn the start amps knob on the 250EX all the way to the left, is it off?
    I'm trying to weld some very thin Aluminum and it doesn't seem to want to start and arc. just fizzles around trying. I've set the amps anywhere fro the lowest to about 30 amps and adjusted the start amps knob all over with no luck.
    It weld fine and starts fine with more amps.
    Also, I've turn the amps down as low as it will go and it says "9". I was thinking this unit would go to 5 amps?
    PowerTig 250EX
    Power I-MIG 200
    Jan 2010
    Chugiak , Alaska
    pleasec give me a call.
    yes all the way to the left is "off".
    Ray
    ____
    Ray
    support@everlastalaska.com
    www.everlastalaska.com
    877-755-9353 X207
    Are you using the foot pedal? AC start is 20 amps.
    Quote Originally Posted by Ray View Post
    Ray
    Yes, using the foot pedal. I don't think there's anything wrong with the welder because it works great for everything else, probably just me.
    You still want me to call you? Today or Monday?
    PowerTig 250EX
    Power I-MIG 200
    Foot pedal isn't as sensitive, and could have a slow spot and for best low amp starts, you should be using the tig torch switch.
    But make sure your unit is in 2T as well.
    Here's one area, I recommend customers looking into the US pedal for more accurate control.
    OK, called Ray.... I'm using 1/16th Tungsten and he recommends smaller Tungsten.
    I'll try the torch switch too.
    So when I turn the Amperage down all the way and it say "9" while in AC, I should not pay attention to the number and just know that the low mark in AC is 20amps?
    PowerTig 250EX
    Power I-MIG 200
  1. New Everlast TIG 210 EXT single control knob, 115/220 V
    By Dragonheart in forum General Welder Questions
    Last Post: 11-29-2014, 02:50 AM
  2. 250EX knob alignment
    By Skeeter in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 03-08-2013, 02:34 AM
  3. Loose amperage knob?
    By sprocket in forum General Welder Questions
    Last Post: 05-01-2012, 09:35 PM
  4. Threaded knob?
    By kidharris in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 11-09-2008, 11:49 AM
