Results 1 to 3 of 3
Thread: powerultra 205
    Default powerultra 205
    what are the amps this unit draws from a 220 outlet? could not find the specs in the on-line owners manual. I read the plasma cutter mode draws 25 amps. what about the tig/ arc portion of the machine ?
    I would have to check the plate of unit. However it should not be more than 40 amps when running it at 200 amps.
    You can run it on a 30 amp, just not at full power.
    If you need the number off the spec plate on the back let me know and I take a look.
    Here is the back, 32 amps. Plus or minus an amp. Bottom middle.
  1. New Powerultra 205's
    By ljdm1956 in forum Pre-sales, Sales and Shipping questions
    Last Post: 02-15-2014, 05:12 AM
  2. PowerUltra 205 arrived
    By jdom in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 11-25-2013, 05:07 PM
  3. powerultra 205 vs powerultra 205p
    Last Post: 03-22-2013, 02:08 AM
  4. powerultra 205
    By travis in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 01-28-2013, 09:33 PM
  5. PowerUltra 205
    By kenwhite in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 05-16-2011, 02:51 PM
