![Quote](images/misc/quote_icon.png)
Originally Posted by
everlastsupport
200EX? Never seen one? The 200DX pedal will not work on the 250EX. 250EX should swing 0-50K (pins 3-4) and 50K-0 (pins 4-5). Also, 6 and 7 should have a short to let the welder know it look at pins 3-4-5 for the amp control.
Would these values and pin numbers be the same to check a 200DX pedal?
Millermatic 211 Mig
Lincoln Weld-Pak 100
Century Stick welder
Jet band saw
