Results 1 to 9 of 9
Thread: why does my post have to be approved by a moderator on certain threads?
    Default why does my post have to be approved by a moderator on certain threads?
    i usually have no problem posting on threads, but today i tried posting to a particular thread, and got a message that the moderator has to approve my post before it will show up. What is going on here? Why would a post that merely asked for an update on an issue need approval before showing on the thread? The thread in question is this one: http://www.everlastgenerators.com/fo...-5th-breakdown
    Last edited by Joe from NY; 01-10-2012 at 09:03 PM. Reason: removed baseless supposition
    Millermatic 211 Mig
    Lincoln Weld-Pak 100
    Century Stick welder
    Jet band saw
    If there is any restriction, I am not aware of it. If it is, then it is likely it is because it is intended for Everlast company use only as a announcement, or tip section, not as a free for all posting of information scalped or relayed from other websites. It is likely it was posted in the wrong section to begin with. That would not be our fault if there is a restriction.
    Yes, i see that now. I removed my baseless supposition so as not to cast aspersion on the board.
    Millermatic 211 Mig
    Jet band saw
    Mark's correct.
    If you have something you feel needs to go in that section, feel free to send it to Mark or I and we will add it for you.
    Nah, thanks. I was only inquiring as to what was the outcome of the brother's problem with his 250EX. I dont know why that thread was in that section anyway.
    Millermatic 211 Mig
    Jet band saw
    Quote Originally Posted by Joe from NY View Post
    Probably why that section requires moderator approval now.
    Posting in the wrong area.
  1. I registered and have not been approved after days?
    By everlastsupport in forum Everlast Announcements, Contests and Promotions
    Last Post: 05-08-2018, 05:13 AM
  2. Replies: 11
    Last Post: 03-12-2013, 05:56 PM
  3. Where are the first few posts of threads
    By Racerryan in forum Forum related Questions
    Last Post: 03-03-2013, 02:20 AM
  4. Negative threads delegated?
    By FabGTO in forum Customer Testimonials
    Last Post: 04-12-2011, 05:53 AM
  5. foot pedal hook up on 205 and collet body threads
    Last Post: 05-30-2010, 02:45 AM
