Results 1 to 5 of 5
Thread: Cheap-Skate-Pipe- Rotator
    Default Cheap-Skate-Pipe- Rotator
    Spent twice as much time fooling with trying to hook a door closer and weight to the flat-belt than grinding today.. ended up just looping it under my roller stand and using my toe to turn it. Worked good on the old steam pipe legs. Seems like the big flap disk will probably spin'er by itself. I'm a dope, was using my grinder for most of it.
ID:	4517Click image for larger version.
ID:	4516Click image for larger version.
    Everlast PowerPlasma70
    Hobart Ironman 230
    Lincoln A-D/C 225
    jakemateer.com
    I like it! A cheap, easy way to weld some pipe
    I was thinking that if I could get the closer hooked up, it would turn it slow and be adjustable. Turns out I've been storing a broken one for 10 years... still in the box.
    Hobart Ironman 230
    Lincoln A-D/C 225
    jakemateer.com
    Thats a good idea. I didnt think of using casters to roll pipe like that. Last time I welded pipe, i set it on a slight open vice and welded a little bit between turning it.
    That is a neat idea, now you'll have to use 2 feet one to roll the pipe and 1 to operate the tig. I haven't had any pipe to weld lately but Ill definitely keep this in mind.
    Everlast PowerTig 200DX
    Snapon FM140 Mig
    Purox Oxy/Acet Torch
    Coleman 80 gal. Compressor
    7x10 Mini Lathe
    Craftsman 12" Bandsaw
    Lots of litler stuff
  1. looking for cheap leads, any ideas?
    By dennis in forum General Welder Questions
    Last Post: 12-13-2011, 12:30 AM
  2. Cheap tubing notcher /holder
    By Jules The Great in forum Hobyist Projects
    Last Post: 11-11-2011, 01:36 AM
  3. Plasma cutting 'table' on the cheap- way cheap.
    By qubit in forum Hobyist Projects
    Last Post: 10-24-2011, 04:10 PM
  4. Sweet bookcase on the cheap!
    By ScratchStart in forum Personal Projects (no welder required)
    Last Post: 05-03-2011, 12:45 PM
  5. Really Cheap $19.98 Tungsten Sharpener
    By JohnS in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 04-21-2011, 04:36 PM
