Results 1 to 16 of 16
Thread: Mini Mig
  1. Default Mini Mig
    I'm loving my Power Ultra 205 and your customer service. I would really like to have a small mig.....maybe dual voltage (110 / 220), 140-160 amps, flux core and Argon Co2 compatible, spool gun available as an option. Do you by chance have anything similiar on the drawing board? I'm not in a big hurry, if you have one on the market by around February would be perfect.:wink:
    Well, we have the PowerMIG 200. And it has an external spool feeder. Small would rule out the spool inside the unit. We have other units in the works.
    160 amp would push the 110volt arena, but not a problem for 220volt side.
    Are you looking for straight DC? Arc force? And what price range would you spend on the unit?
    We do have some smaller migs on the way. They will be in this next shipment whenever that is...
  4. Default RE:
    By small I was referring to amperage (<200) with a nice compact gun for getting into tight places for welding on rollcages. I'm not super familiar with the smaller machines but I believe most of them are limited to approximately 2 lb spool. I'm thinking in the $350 neighborhood for a 140-160 amp machine. I'm not sure what arc force is. Any ball park idea when these may arrive. I realize they may be on the slow boat :-)
    roadymi,
    Don't look for them to be too cheap. They will be in the range you are looking for though.
    These are inverter machines. Typical transformer machines in the price range you are looking at are poor performers, with lousy duty cycle and unstable arc characteristics. Transormers are cheaper to make and inverters are more technologically advanced...hence the higher price. We do have a cheap transformer welder at our disposal, that should be reliable, but it is not our desire to offer the lowest quality product to our customers just to save them a little money, especially where migs are concerned.
    Ours will likely be in the 500-600.00 range. They use Binzel MIG guns, among the finest in the industry. I think they all will accept a 10 lb roll. Depending upon the model, they have an addtional stick weld function. And these are half the weight of the equivalent transformer MIG.
    Arc force for a MIG machine affects the arc properties and it helps to fine tune the welding arc to suit your taste and welding style. Some older references call this a "choke" and fine tunes your machine to make it weld exactly how you want it too.
    The boat isn't so slow as China is on a two week national holiday...with 4 days of "national 60th birthday" and a traditional 4 day fall break. Look for things to hit high gear after the 9th.
    Thanks for the feedback.....looks like I will need a slightly larger piggybank than I was hoping.......oh well......such is life.
    If you are welding roll bars by all means get a good welder as your life or someone else’s may depend on a good strong weld.
    Wayne
    I think Roadymi is on to something. Maybe a thread asking "what would be the ultimate machine you would want and how much would you pay"?
    Detailed specs and price range.
    We at Everlast have talked about a portable plasma cutter for over a year and it's still on our list. Not enough demand to justify it based on the cost. I personally want one, but we too have a piggy bank.
    We import our machines from our factory after the design phases. Under $300 is not going to happen as, the cost, shipping, US customs/duty, company overhead and so on.
    There are a lot of hidden cost but we deliver quality, feature rich, products.
    Other companies charge a lot more for their units that do less than ours.
    Quote Originally Posted by WAYNESWORLD View Post
    Wayne
    Don't worry Wayne, I value my neck as much as the next guy. It's just that I want a really good welder.......at a really really good price. I just don't need to weld 1/2" steel. I don't need a 200 amp machine to weld the 3/16" and thinner stuff that I will be working on. Typical roll cage tube is .087 to .120. I really really hope that my welding skills on the cage never gets tested. I've been upside down twice....two times too many already.
    I have faith these guys can produce what I need.
    As long as you asked, why not build the ultimate machine....arc, tig, mig & plasma?. It seems you have 2 or 3 of the above combined in different configurations, why not all 4?
    Just a thought.
    Roadymi,
    There are a lot of parts competing with the same "air" space as it is in our current machines...I won't say the technology is tapped out, but it is pushing practicality to the limit. You will see 3 technologies combined into one, but adding the 4 to any possible combination, defeats the portability, and practicality of what we are trying to do. You will see Mig, Tig, and Stick combined in many power sources as inverters are quite able to handle CC and CV issues. But something has to be sacrificed, whether its portability, simplicity, functionality, or reliability, when adding another complete system. A lot of other companies refuse to add plasma to their list of functions just for this reason. A plasma is portable and quite easy to move around, especially for the amperage we are talking about, but when combined, you have extra weight of boards, and need for more space to allow things to cool and operate properly. Switching constantly between processes also is tiring for many. Many of our customers buy separate units for this reason. But anytime you add a mig to a welder, you have a LOT of extra added weight, making the machine not quite portable and not quite big enough to be a stationary either...making it a undesirable product in many home shops and commercial garages.
    That all makes sense, I guess that's why you guys are in the welder business and I just "pass gas" all day. Just goes to show why some things that sound good on paper just arn't feasible.
    I am really rooting for you guys to be the next miller, lincoln,esab, in the industry, I think you have all the componets as in service and product, to make it work! Keep up the good work!!!
    Your sentiments are appreciated.
    I wish we could tell you right now what all we have planned for the future...but it would ruin the anticipation. Our new lineup has been a success and we are trying to improve upon it as any company would. We have a completely new product in the works now that is as nice or nicer than anything from the large three. But, we are being quiet about some of the details for obvious reasons.
    A few things are taking longer than expected, but we don't want to be the Microsoft of the import welder company and release something before it has been debugged and proven ready just to stay ahead or to have something new.
    We will also be "ramping" up our marketing strategies...
    "Look for a welder coming near you..."
    Quote Originally Posted by smackdaddy View Post
    Thanks for the support. We all work very hard.
    Being a Miller is our direction. It takes a little time. This year a new design and IGBT. And I can not believe it is October already. That one went fast.
    As Mark stated, just wait.
    Maybe we can post pictures once the proto-type phase for us is done. We will see.
  16. Thumbs up "props"
    Oh and not to forget about the guys or gals behind the web site, its fantastic and keep letting the ney sayers in here to voice there opinions too. Everybody has a right to speak their minds, weather it be good or bad.
  1. PROJECT 4 from Jerky: mini bike fenders
    By jerky in forum Other Custom Fabrications
    Last Post: 01-30-2012, 05:47 PM
  2. Mini project update.
    By Ram48 in forum Personal Projects (no welder required)
    Last Post: 05-25-2011, 11:37 AM
