Results 1 to 7 of 7
Thread: PROJECT 3 from Jerky: coffin gas tank
    Default PROJECT 3 from Jerky: coffin gas tank
    Yes you read that correct, a coffin gas tank. My buddy has a small 50cc chopper and he wants a bigger motor in it. So we stripped it all down. I made a deal with him so now im makin his tank. Dont ask me why he wants a coffin, all im doing is building it. Im using 1/16" sheet metal. Its about 1' long, 7" at the widest and 4" deep. I build the rough box tonight while i was waiting for the vht to dry on my taillights. Tommorrow i will make a tunnel for the bottom so it can slide down onto the frame. Heres what i did tonight...
    Journeyman welder
    250EX
    Power plasma 60
    horizontal band saw
    doesnt the top have to angle up or else you would be mounting it horizontally flat, and the top frame tube coming back from the neck to the seat post is probably not flat. I am used to seeing something like this:
    most of the tank should sit lower than the filler neck.
    Millermatic 211 Mig
    Lincoln Weld-Pak 100
    Century Stick welder
    Jet band saw
    I wouldn't go too much bigger, with the price of gas these days...
    Everlast PowerPlasma70
    Hobart Ironman 230
    Lincoln A-D/C 225
    jakemateer.com
    Put the cap on today
    Journeyman welder
    250EX
    Power plasma 60
    horizontal band saw
    Finally made it back to the shop tonight and spent some time on the tank. I cut the tunnel down and split the bottom so i can weld it to the tunnel. Once i got everything cut i drilled a small hole near the bottom so i can weld a nipple on. I didnt take a pic of the nipple yet. I will weld the nipples on first before i weld it all together. Should be all done tommorrow and ill take some more pics.
    These are just after i cut the tunnel and split the bottom.
    Journeyman welder
    250EX
    Power plasma 60
    horizontal band saw
    Pretty funny when you see the size perspective of it next to the tape measure. What's the plan for the wavy edges, weld the sides down and grind them off?
    Hobart Ironman 230
    Lincoln A-D/C 225
    jakemateer.com
    Dont know what you mean by wavy edges, its all flat but there are grinder marks along all the edges, maybe thats what your seeing? Didnt end uP finishing it this weekend because he didnt like how deep it sat on the frame. So heres some more pics, the nipples are just regular greese nipples, with the ball taken out.
    Journeyman welder
    250EX
    Power plasma 60
    horizontal band saw
  1. School project from Jerky (3g tig root)
    By jerky in forum Hobyist Projects
    Last Post: 02-20-2012, 04:23 PM
  2. PROJECT 4 from Jerky: mini bike fenders
    By jerky in forum Other Custom Fabrications
    Last Post: 01-30-2012, 05:47 PM
  3. PROJECT 2 from Jerky: welding cart
    Last Post: 01-22-2012, 01:49 AM
  4. PROJECT 1 from JERKY: tig cooler
    Last Post: 12-30-2011, 10:50 PM
  5. Quench Tank Project
    Last Post: 03-26-2011, 03:01 AM
