Results 1 to 20 of 31
Thread: Project #3 Another another Welding Cart
    Default Project #3 Another another Welding Cart
    Well my 200DX is sitting on a table with th cord stretched across the room, and the Argon tank is on the floor, So its time to build a welding cart. I started with 1x1 angle, it will be 16x30" I got the perimeter made so far.Click image for larger version.
ID:	4623Click image for larger version.
    Everlast PowerTig 200DX
    Snapon FM140 Mig
    Purox Oxy/Acet Torch
    Coleman 80 gal. Compressor
    7x10 Mini Lathe
    Craftsman 12" Bandsaw
    Lots of litler stuff
    Used some scrap and welded the mounts for the front casters.
ID:	4629   Click image for larger version.
ID:	4630   Click image for larger version.
    Snapon FM140 Mig
    7x10 Mini Lathe
    Got the hole drilled in the mounts and the casters bolted on.
    I have a pair of pneumatic wheels but the centers are 5/8 and I picked up 1/2 inch rod, so back to the steel yard tomorrow.
ID:	4632   Click image for larger version.
    Snapon FM140 Mig
    7x10 Mini Lathe
    Pneumatic wheels roll nice, but how often do they go flat..
    a piece of copper 1/2 tube might shim those axles for ya.
    Everlast PowerPlasma70
    Hobart Ironman 230
    Lincoln A-D/C 225
    jakemateer.com
    They still hold air after a year, but their not mounted to anything. That wouldn't be good if 1 goes flat ,then have the possibility of it tipping over. I bought them over a year ago for another project but never used them. Maybe a trip to the hard ware store indtead.
    Snapon FM140 Mig
    7x10 Mini Lathe
    I went to Menards and picked up some solid wheels, got home and tried to slide em on my 1/2 rod, They wouldn't fit , turns out the rod I picked up at the scrap yard was 13mm not 1/2 inch. nothing the lathe couldn't handle. cut a piece of 1/8" plate for the tank to sit on and tigged in place.
ID:	4643   Click image for larger version.
ID:	4644   Click image for larger version.
ID:	4645   Click image for larger version.
ID:	4646   Click image for larger version.
    Snapon FM140 Mig
    7x10 Mini Lathe
    This side cabinet was hanging on my toolbox roller cabinet, It had nothing but junk in it, so I emptied it out and set her on the cart, lots of space for consumables, torches, pedal, stinger etc. Its not long enough and I'll have to extend the back of it.
    Snapon FM140 Mig
    7x10 Mini Lathe
    Paint that thing green!
    Hobart Ironman 230
    Lincoln A-D/C 225
    jakemateer.com
    I like to but Im up here in MinneSNOWta and its about 3 degrees and no heat in the garage.
    Snapon FM140 Mig
    7x10 Mini Lathe
    Got some more done tonight. I ran out of angle iron so had to use some square tubing, also to top plate was to short so it was made in 2 pieces. all I have left to do is the side brackets to mount the cabinet to the cart and the tank strap. some stuff is a crappy lookin , I was in a hurry, Even when Im not in a hurry my stuff is crappy lookin
ID:	4666   Click image for larger version.
ID:	4667   Click image for larger version.
ID:	4668   Click image for larger version.
ID:	4669   Click image for larger version.
    Snapon FM140 Mig
    7x10 Mini Lathe
    Well the uprights and table extension is done just have the brackets to mount the cabinet to and the tank strap. then its on to some hangers for it and some filler rod tubes.
ID:	4674   Click image for larger version.
    Snapon FM140 Mig
    7x10 Mini Lathe
    It's coming along, looks rugged.
    Hobart Ironman 230
    Lincoln A-D/C 225
    jakemateer.com
    My impatience really starts to show toward the end of a project. I finished the tank strap and safety chain thingy.
    Snapon FM140 Mig
    7x10 Mini Lathe
    One thing I like about it is I can remove the cabinet and carry it up the basement steps
    Snapon FM140 Mig
    7x10 Mini Lathe
    Ok , I got the side bracket to hold the filler rod container tubes done. This is the second one I made, the first one I screwed up on so I wont bother posting pics.
ID:	4715   Click image for larger version.
ID:	4716   Click image for larger version.
ID:	4717   Click image for larger version.
ID:	4718   Click image for larger version.
    Snapon FM140 Mig
    7x10 Mini Lathe
    I used pvc to make the tubes, glued caps on the bottom and bolted them to the bracket, cut my filler rod in half to 18"
ID:	4770   Click image for larger version.
ID:	4768   Click image for larger version.
ID:	4769   Click image for larger version.
    Snapon FM140 Mig
    7x10 Mini Lathe
    Dec 2011
    RUSSIA.Sankt Peterburg
    Quote Originally Posted by Buzz View Post
    Good idea Buzz, it is necessary to add in the arsenal
    Ruslan
    EVERLAST Power Tig 255 EXT
    EVERLAST PP256
    PC300
    EWM Pico 162
    MERKLE mobimig 180K
    SELCO Genesis 352 pme
    Quote Originally Posted by donor76 View Post
    I thought it was a good idea too but its not mine, I stole from forum member CGCING http://www.everlastgenerators.com/fo...er-rod-holders
    Snapon FM140 Mig
    7x10 Mini Lathe
    Dec 2011
    I think that CCGNC not in insult.
    For this purpose also the forum is intended what to share with other good ideas.
    At your forum I have gathered many interesting ideas.
    As says in Russian proverb:- the Century live, the Century learn
    Ruslan
    EVERLAST PP256
    PC300
    EWM Pico 162
    MERKLE mobimig 180K
    100 years to live, 100 years to learn.
  1. First Project: Welding Cart
    By Glassbeaver in forum Other Custom Fabrications
    Last Post: 06-19-2014, 04:51 AM
  2. Yet another welding cart project!
    By HemiRod23 in forum Other Custom Fabrications
    Last Post: 06-26-2013, 09:10 PM
  3. welding cart/cooler project
    Last Post: 01-05-2012, 02:11 PM
  5. Project 2 SeanMurphy265, Welding Cart do-over
    By SeanMurphy265 in forum Hobyist Projects
    Last Post: 06-18-2011, 09:28 PM
