Results 1 to 5 of 5
Thread: everlast 230ex
    Default everlast 230ex
    Hi All
    anybody out there using the 230ex evelast tig /stick . I bought one mid last year and are still learning how to use it . Its a great machine I would just like some hints about settings and gas flow rates when welding aluminuim.
    Hi Nevillemonty
    The 230 EX is a Australian welder so i assume your from that neck of the woods.
    I don't get to use the 230Ex that often as i only ever get the opportunity to try it out if it is in production while i am visiting our Manufacturer.
    The 230 has all the same or practically all the same features as the 250 Ex and the only real difference is the fact that it is more compatible with the average electrical power output that is typical for you. If you go to youtube ( or there are links to the videos on our Forum )you can see a Series of Videos that have been produced on weldingtipsandtricks
    Cheers
    EVERLAST CANADA
    www.everlastwelders.ca
    www.titanwinches.com
    905 637 1637
    A good starting point for aluminum.
    Turn off the pulse, turn on AC, set for TIG, set the AC frequency to the 2 o'clock position and the balance to the 10 o'clock position. AMPs should be about 1.25 amps per .001 thickness.
    That should get you started.
    Many Thanks
    Nevillemonty
    EVERLAST CANADA
    Yes from Queensland, Thanks for the tips, I have been watching the videos.
    Many Thanks
    Nevillemonty
  1. probs setting up my 230ex
    By nikstiks in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 11-29-2013, 08:52 AM
  2. spot welding with my PowerTIG 230EX
    Last Post: 04-05-2013, 01:03 PM
  3. Everlast Ebay vs Everlast direct sales
    By zoama in forum Pre-sales, Sales and Shipping questions
    Last Post: 12-17-2011, 09:46 PM
