Results 1 to 2 of 2
Thread: Defender Helmet
  1. Default Defender Helmet
    Was doing a little tig welding today and the new defender helmet acted up. Mid way through a bead the shade went off...talk about a blinding experience!!! Also, it beeped at me on a few different occasions. Whats going on here. Battery gauge shows a full charge.
    I would go ahead and replace the battery, anyway. The battery could be shorting internally, or the contacts inside the battery could be detaching. When you replace the batteries, check the metal contacts on the helmet and make sure they are making good solid contact with the battery.
    If that doesn't work, then check that the light sensors are clean and not blocked by anything... if none of that is the problem, then it's time for a new helmet... or a call to the manufacturer and/or retailer.
    Spike Customs, Inc.
    Fresno, CA 93727
    ph- 559-549-RIDE(7433)
    -Follow me on twitter!-
  1. What welding helmet are you using?
    By 225 in forum General Welder Questions
    Last Post: 11-15-2013, 06:06 AM
  2. helmet ?
    By travis in forum General Welder Questions
    Last Post: 11-14-2013, 11:50 PM
  3. How safe is an old helmet?
    By DaveO in forum General Welding Questions
    Last Post: 01-25-2013, 08:48 PM
  4. Best Helmet?
    Last Post: 03-27-2012, 02:55 AM
  5. Defender helmet
    By Steveg in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 08-11-2010, 10:41 PM
