Nice set up! i`m using the same pump without the isolator, i`m using a car condenser and the outlet of the condenser is significantly bigger than the inlet, this then illiminated any pulsations at lower pressures, i usually run my cooler at 50 psi
Gil
powerpro 256
lincoln 185
