Results 1 to 8 of 8
Thread: Aluminum Specialized Bicycle Seat Post Clamp Repair (TIG weld)
    Default Aluminum Specialized Bicycle Seat Post Clamp Repair (TIG weld)
    I TIG weld repaired a broken seat post clamp for a pretty high end Specialized Road bike.
    It failed from overtightening. The owner's manual only calls for something like 4 foot-pounds.
ID:	7266 Click image for larger version.
    I started by vicing it and hammering it a little closer to undo the stretching that had occurred. I also used vice grips to massage it back closer to its original shape.
ID:	7259 Click image for larger version.
    After getting it massaged into rough shape, I used carbide burr to vee out the bulk of the crack, to prep it for TIG welding with full penetration. I also dressed it with a file, and used some solvent as well to prep things clean and dry.
    I had an .040" tungsten in there, so I went with it. A little helium mix. It was fun welding with that little tungsten and the helium! I used an arc down to 2 amps AC (indicated on my machine's display at least) Who knew helium could be sustained with stability at such low amperages. It was small enough current I had good control of the puddle despite this part being almost jewerly-sized. After fully penetrating the weld repair, I built the surface up for some additional strength that the part never originally had. I should have taken a picture before I did the build-up, but didn't get one; oh well.
ID:	7261 Click image for larger version.
    I never use a cup this small... but figured what the heck let's give it a try. It was a #4. (And in hindsight, shielding probably would have been noticeably better if I had a #5 on there.)
    Then I took the welded surface down to the final desired dimensions using things like the 4.5" angle grinder with flap disc to get things "roughed" into shape, followed by some flat hand filing, drilling, and counter-sinking. Surfaced it on my granite surface plate with spray-mounted sandpaper. Finally, grained it evenly with a maroon scotch-brite hand pad. Didn't that that long since it was such a small part.
ID:	7262 Click image for larger version.
ID:	7263 Click image for larger version.
    The part being build up higher than it was originally where it failed, means it is more rigid than it was new and likely stronger, too.
    Machine used: Everlast Super200P. 1/16" 5356 filler rod.
    Nice job! That clamp sure didn't have much meat to it. No wonder it failed. Amazing you were able to keep the arc going with so little amperage. Amazing machine in the hands of a good welder. Cheers!
    Yowza, nice work as usual. I wonder if the guy bought the wrong size seat post, a shade too small, and thought he could crank down on the clamp to compensate.
    Sometimes a little chalk dust rubbed on the mating parts can minimize slippage, and the tendency to overtighten.
    I use to ride a Specialized mtn bike until it was stolen.... That's not a good design I would have problem with mine getting loose after a long ride. That aggravating part is the seat height has everything to do with comfort on the bike. I was tempted to drill a hole and run a pin through my seat post.
    Very nice work ... Looks like a brand new clamp. Isn't the clamp installed backwards in the second picture? It seems like it should be squeezing on the split part of the seat tube.
    Cheers
    Mike
    Power Pro 256
    Thanks, and I know what you mean about the clamp looking like it's installed backwards. I initially had the exact same thought. However, that is how the owner's manual says it should be installed. The manual even explains something about it being that way to avoid deforming the slit tube opening.
    Very nice! You Definitely get more fun out of doing something yourself instead of buying it; especially when you can make it better!
    My brother and I were thinking about building a go kart a while back; dad said just buy one...he just doesn't get it...
    Benjamin
  1. Monday morning quarterback: bicycle weld
    By DaveO in forum General Welder Questions
    Last Post: 04-08-2013, 07:04 PM
  2. Replies: 8
    Last Post: 12-05-2012, 05:04 AM
  3. Aluminum mountain bike rear suspension TIG weld repair
    Last Post: 06-21-2012, 01:06 PM
  4. Replies: 5
    Last Post: 06-18-2011, 08:14 PM
  5. Tubular aluminum Pontoon boat frame TIG weld repair
    Last Post: 06-15-2011, 03:05 PM
