Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
Thread: What to use to cut Diamond Plate sheets?
    I have a band saw that uses a little 110v motor with a metal blade. If you don't rush it it cuts sheet metal just fine. Ive cut aluminum, steel, stainless, and copper all with no problem.
    Power tig 225lx
    Hand tools up the wazoo.
    ok cool. I have a little 110 band saw that I might try that with. How thick of stuff can you cut with it.
    Gabe
    everlast power arc 200
    lawn mowers
    I can cut 1/4 aluminum no problem. You'll want one with a little bigger teeth for aluminum so they don't get clogged up. I've cut 1/4 copper bars, 14gauge stainless and 1/8 steel plate. Don't feed it too hard, just ease the cuts along. On mine you can hear if the motor is struggling or not.
    Power tig 225lx
    Hmm ill have to see about getting a metal blade. Mainly would just be using it for quick little cuts that dont want to get the saw saw out or chop saw.
    Gabe
    lawn mowers
    I forgot to mention on the ferrous metals you just want to watch out for excessive heating as not to work harden the metal. If this happens its a pain to cut through especially on stainless. Also though I was always told not to wear gloves around moving blades, I wear them when cutting the smaller stuff especially copper and aluminum cause it gets hot.
    Power tig 225lx
    I can tell you that wood bandsaws run at much higher speeds (talking about feet per minute of the moving blade) than metal cutting bandsaws. It might work OK on aluminum though. I hear that generally speaking, a setup that is good for cutting hardwood, works well for aluminum too.
    I've seen skillsaws used very effectively for cutting aluminum sheet in the 1/16-1/8" thick range. Clamp a straight piece of wood to the sheet to use as a guide if possible, and use a blade with carbide teeth. Might need to wear hearing protection.
    I remember seeing this baby sized skillsaw (circular saw) that worked great on aluminum and was nice and compact too. Its blade was smaller diameter than most and I remember the blade being more lined up with the handle than the average one so it seemed like it wouldn't torque on your wrist and seemed a little safer to me. I wish I had that one.
    [edit]
    Oh, I almost forgot to add.... I know they make cutoff wheels for aluminum too. I've been meaning to pick one up to try for my 4.5" angle grinder. I have a 4.5" grinding wheel for aluminum and find it's a *really* useful tool. Normal cutoff wheels and grinding wheels are no good for aluminum though, because they load up. The kind made for aluminum seem to shed their abrasive grains more aggressively than standard grinding wheels, and at least for that reason, don't get as loaded up (and actually work.)
    Dec 2011
    Knoxville, Tennessee
    I shear the straits and band saw the profiles. However if you don't have a shear or band saw you can use a circular saw with a carbide blade and a jig saw for profiles... Bosh makes the best jig saw bar none and the best blade as well.
  8. #28
    Nova Scotia, Canada
    Wood working bandsaws work great despite the high SFPM but leave a rough finish. The only real issue is that they can clog up, especially with gummy aluminium. Hosing 'er down with WD-40 helps a lot. You'll know when it happens as the blade stops cutting well and your aluminum gets really hot. Stop and you'll find the gullets have aluminum smeared in them.
    I don't think this is what you are interested in, but adding this for completeness.
    No one has mentioned the basic electric jig saw. A jig saw would probably cut through that aluminum as fast and as straight as a Plasma cutter.
    Has anyone used stick lube?
    http://www.sri-supplies.com/hougen-m...-11746-12.html
  11. #31
    I have not tried that. But candle wax works well with the bandsaw blade.
  12. #32
    We cut up to 3" thick plate with a large handheld crcular saw. It is a big air powered industrial unit.
    For sheet / plate up to 1/2" we use a milwaukee panel saw http://www.milwaukeetool.com/tools/s...el-saw/6480-20
    there are quite a few companies that make metal specific circular saws and blades. A standard circular saw will work as well for light duty use.
  13. #33
    Did not even think about a panel saw, probably as good as a shear and a lot cheaper.
    Miller Matic 185
    Everlast 250EX
  14. #34
    I've used something similar. Its a low melting temp cutting compound in a tube. Works good for tapping holes, especially on Nickel/Aluminum/Bronze which is a tough metal to machine. I haven't used it on any saws though.
    Power tig 225lx
  15. #35
    I picked up a Ridgid 14" wood cutting bandsaw off craigslist for $150 practically new, they said it didn't work but it was only missing the safety switch. Went to Lowes and bought a 18TPI metal band saw blade and I have used it for cutting .1 Aluminum sheet, and 1/4" Aluminum plate and it works GREAT.
  1. Desk Name plate
    By acourtjester in forum Metal Art
    Last Post: 01-25-2013, 07:39 PM
  2. Diamond Plate Project with PP205 Plasma with Pics
    By Buggy Chief in forum Everlast Plasma Cutters (PAC)
    Last Post: 05-30-2012, 01:28 AM
  3. Anodized Aluminum Diamond Plate
    By Buggy Chief in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 01-13-2012, 11:56 AM
  4. Aluminum diamond plate flooring, for a fishing boat (jakeru's #10)
    Last Post: 07-15-2011, 04:19 PM
  5. Diamond Plate TIG Cart
    By dave s in forum Other Custom Fabrications
    Last Post: 03-29-2011, 06:09 PM
