Results 1 to 15 of 15
Thread: My new 225lx
    Default My new 225lx
    My welder just got here via the big brown van. Opened up the box, no shipping damage. Hooked up all the hoses. Put a 50amp plug on the power cable. The following picture are some test welds playing around with the settings.
    Just a question is the fan supposed to run the whole time? As soon as I turned the power on it started running.
    Now I'm off to build my first project.
    Power tig 225lx
    Hand tools up the wazoo.
    I've got a 200 and the fan starts when I flip it on, I'm assuming yours is the same. Based on what I've read in other posts that's the way they're set up. Keeps it nice and cool but it is a bit noisy :-)
    I believe the fan is suppose to run the whole time. Its not a fan-on-demand setup
    Everlast lx225
    Hobart Stickmate LX
    Thermal Arc 400GMS
    10"-22" Grizzly lathe
    Yea. I've done some research and came to that same conclusion.
    Power tig 225lx
    That's the reminder that the unit is still turned on.
    Its not a bug; its a feature!
    By having fan on all the time , we get better duty cycle out of the unit
    Oleg Gladshteyn
    Good one ..
    Oleg Gladshteyn
    I actually like the fan on all the time. Its not loud at all. I dont even hear it running. I usually have the radio on anyways. Also ya have less to go wrong, higher duty cycle and its quieter than my old lincoln which is on all the time too.
    Gabe
    everlast power arc 200
    lawn mowers
    I like the fan being on all the time myself. Looks like your off to a good start!
    I'll get use to the noise. I'm use to a quiet shop, since its only me.
    So far I like this welder it has an easy user interface. I'm not use to a flow meter with liters per min that will take a little time to get use to tuning for different things.
    So I dropped a piece of steel onto my foot pedal cord, it cut through it in two pieces. I will have to make some splices tomorrow. I didn't want to break my groove so I tried out the torch button. So far I like it. The only problem is since I'm not use to having a button on the torch I accidentally hit it in 4t and got arc flash to my face and eyes. This is the first time its been this strong. right away I could smell a little toasty skin. I was about 1.5' form the arc. My face is a little toasty, my eyes are throbbing and I have a headache. And my vision has a big spot and is a little blurry. That is a touchy switch.
    Power tig 225lx
    It might not be a bad idea to go get it checked out if your seeing a spot.
    They may want to use some antibiotics and patch them.
    Oh man I'm sorry to hear that. I was welding one day and when I stopped I realized my niece was watching me for the last 30 sec from what I could gather. I didn't even know they were over I was so worried that she had hurt her eyes. She is only 4 so she didn't know it was bad to look she just wanted to say hi. Luckily I was only welding at about 30 amps and she didn't hurt her eyes.
    Everlast PowerTig 250EX
    Everlast PowerCool 300
    Everlast PowerPlasma 70
    Lincoln Powermig 215
    Magnum SG Spool Gun
    Don't jump on my Gomba
    Quote Originally Posted by dyethor View Post
    geezer posted up a nice rule of thumb on that not too long ago, flow in lpm should be equal to the cup size, 1 or 2 less for a gas lens, +1 for higher amps (200 or more IIRC)
    If you are use to using a Miller with fan on demand, the constant fan noise it is a change at first. I do not desire the fan to be on all the time but the initial irritation has gone away for myself and I do not even notice it is on much when I start welding.
    I remember I was doing little tack welds once without my helmet, just blinking my eyes shut and firing a brief high-amp arc, to make small tack welds. I did do quite a few of them - 20-40 or so and high amps (but brief.) I ended up sunburning my face on that!
    After that painful experience, I haven't skipped out on the helmet (even for just those really quick tack welds.)
    My super200P has its fan on all the time with the power on, but it's a pretty mellow noise. Really moves the air through the vents too...
  1. 225lx??
    By THUNDER351 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 04-20-2012, 07:38 PM
  2. 225LX can't seem to get it to tig..
    By Hayapower in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 12-10-2011, 12:57 AM
  3. Just got my 225LX and tried it out
    By DiabolicZ in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 04-02-2011, 08:01 PM
  4. my new 225lx
    By paintmegone in forum Customer Testimonials
    Last Post: 06-15-2010, 05:23 PM
  5. 225LX on the Way !!!
    By alexm in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 02-16-2010, 11:19 AM
