Originally Posted by
performance
Ray, ... Lift start doesn't have anything to do with being hot or not. On the 140, the current is hot all the time and there is no switch. On miller inverters, such as the 304 and the maxstarts, scratch start and lift start both work without the use of a switch. I have used the XMT models for hundreds of hours in both modes. The tip is live, but when it senses contact with the metal, it reduces current flow, and when it lifts up it sends a burst of power down the line to start the arc. I also have used it for welding on bobcats as well. The 185 may start as a lift start without the HF, but it definitely doesn't have anything to do with it being live all the time...both may or not be controlled with a torch switch to energize.
