Results 21 to 40 of 43
Thread: Project twin scroll
    Excellent work. You didn't cut any corners, and it shows. Thanks for sharing!
    Wow that is really nice. I wish I could weld half that good. Stainless looks so great.
    Do you bend the pipe yourself or get prebent sections and cut to fit... Even the cuts look tight. Thanks for the pictures.
    Shade tree MIG welder.
    Now a Shade tree TIG welder.
    Quote Originally Posted by tt ws6 View Post
    Awesome fab work. I'm curious which model Everlast welder you're using? I plan on doing my hotside on my Trans Am here soon. Also, where or how do you get that polished look on the stainless? Is that something you do, or does it come like that?
    Model does not matter. The hand does the welding, not the machine. All you need is a footpedal.
    Cutting corners is doing it the wrong way.
    I buy them pre-bent.
    Quote Originally Posted by Boosted P View Post
    Do you ever find the mandrel bend to be smaller than the unbent part of the tube ?
    if there mandrel bent that should not happen. when tube is crush bent, then the bend does reduce in diamater. thats usually why mandrel bent stuff is more expensive
    Journeyman welder
    250EX
    Power plasma 60
    horizontal band saw
    This was 60mm mandrel bent 304. The bend part from a 180 and a 45 was about 1mm smaller in diameter. So when I tried to fit part of a turn to a straight piece, I couldn't get a nice clean joint.
    I had to blend the joints and use a brushed finnish instead of polishing.
    how thick was the tubing
  8. #28
    A little trick a bender showed me when bending thin tubing he would fill tube with fine sand and cap both ends then bend then tubing wouldn't shrink while bending
    That is some nice work! After you weld everything together will it bolt up easy or does welding tweak it?
    The tubing is .065 wall.
    It is not mandrel bend tubing...this is what I use:
    It is a sanitary fitting, and has the same diameter all the way through. These are perfect.
    The flanges and flex pipe gets welded last, this it to allow for proper fitment. The stainless dos shrink a fair bit when welded.
  11. #31
    where would you get this?
    Journeyman welder
    250EX
    Power plasma 60
    horizontal band saw
    From me
  13. #33
    Google- sanitary fittings butt weld.
    Nice going, you gave away the greatest secret of all time.....GOOGLE.
  15. #35
    most stuff i work with is .125 wall tubing with my mandrel bender it doesn't like thin stuff tends to stretch and not stay the same size when bending .065 is thin stuff to bend
  16. #36
    yes i can use google, but i figured since you in alberta, you have a source close to home.
    Journeyman welder
    250EX
    Power plasma 60
    horizontal band saw
    Well, if you want to buy this stuff in Alberta you will pay 2.5x what you would pay for it down south.
  18. #38
    Awesome work! I'd like to do headers for my 240Z at some point, there are some on it now but they are not well thought out.
    What are you doing to get such uniform ovals out of the round tubing going into the flanges? Your not just bending them in a vise are you? I would think that would "pinch" the mid-point on the tubing. Are you buying some pre made stuff for that?
    H: PowerTig 250EX
    W: Lincoln Precision Tig 225
    W: MK Products CobraTig 150 orbital welder
  19. #39
    Do you experience any heat issues with the transmission or other parts? Do you find any value to ceramic coating the hot side tubing or using a turbo heat cover in an application like this? S/F.....Ken M
    Lincoln Power MIG 300
    Everlast 160STH
    Miller DEL 200 welder/genset
    Miller XMT300
  20. #40
    Too bad all of that nice work is going to be hidden from view. Really nice job and it looks like it won't reduce under-car clearance much at all.
    I'm curious about this as well.
  1. Project #11 From Jason: MK3 AWD 3.4L Twin Turbo Jetta
    Last Post: 06-05-2013, 05:35 AM
  2. Twin turbo mustang intake
    By Zmechanic in forum On Road Fabrication
    Last Post: 04-28-2013, 06:46 PM
  3. Project 1 From TT WS6 - Twin Turbo Trans Am
    By tt ws6 in forum On Road Fabrication
    Last Post: 12-09-2012, 12:27 PM
  4. Project 1 from Injected65. Twin Turbo Kit
    By Injected65 in forum On Road Fabrication
    Last Post: 06-01-2012, 07:39 PM
  5. Replies: 12
    Last Post: 03-10-2011, 08:25 PM
