Results 1 to 5 of 5
Thread: Pu 205 questions please
    Default Pu 205 questions please
    Hi, I'm finally getting around to practicing with my pu205. I have two questions:
    1) when I was using the plasma cutter, after a cut, the air wouldn't quit coming from the nozzle until I turned the machine off and start over again?
    2) I'm practicing with my tig using the foot pedal:
    A) I can't set the amperage, or I'm doing something wrong. I was trying to set the amperage to, say 50 amps max, but it still goes to max despite the machine being set at its lowest amp. However, the display reads -006, doesn't go to zero, is it supposed to go to zero with the foot pedal let off?
    B) the argon keeps flowing after I let off of the pedal, unless I turn the machine off. Argon is going quickly at this rate. Yikes!
    Thought I'd try here before calling tech; )
    Dne'
    My work area for practicing, pretty cool?
    Darn, just tried calling tech but their mailbox is full and I wasn't able to leave a message. : (
    Quote Originally Posted by Dne007 View Post
    does it continue for longer than the setting you have your post flow on?
    please will contact Ray at ext 207 .. VM issue is fixed now
    please
    Oleg Gladshteyn
    I only have about 2-300 pounds in my tank, but I checked the post flow. The knob wasn't on correctly, not that it makes any difference, but I pulled it off and put to "0". All n all, I think you solved my problem! However, the argon was shutting off just fine, then began to keep flowing the more I tigged. I wouldn't consider what I was doing excess excessive, just little pieces of thin scrap. Wow, Tech just called, and I had played with the post flow just before he called, and it seems to be working just fine for the tig. I'll work with the plasma tomorrow, ( with him on the line would take too long to swapfrom tig to plasma) maybe I overloaded the machine by cutting too much too quickly, like maybe taxed the duty cycle? I thank you!!!!!! and will have tank filled tomorrow and give both the tig and plasma cutter a little workout! I love my little machine and would fear for it to break!
    Dne'
  1. Questions About I-Mig 140
    By esg612 in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 02-22-2017, 06:26 PM
  2. New guy with 250ex questions.
    Last Post: 01-29-2013, 10:11 PM
  3. 256 questions
    By tnc110 in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 05-02-2012, 01:03 PM
  4. spool gun questions
    Last Post: 10-25-2011, 01:34 AM
  5. 250EXT Questions
    Last Post: 09-08-2011, 01:20 AM
