Results 1 to 14 of 14
Thread: Project #2 Welding Cart for 225LX, TIG Cooler, and eventually a Plasma Cutter
sw2x Project #2 Welding Cart for... 03-17-2012, 07:53 AM
everlastsupport Not bad far as the welds go,... 03-17-2012, 12:22 PM
sw2x Spent some more time last... 03-19-2012, 03:46 AM
sw2x I was off to a good start... 03-20-2012, 10:22 PM
dyethor Have you figured anything out... 03-21-2012, 04:29 AM
    Default Project #2 Welding Cart for 225LX, TIG Cooler, and eventually a Plasma Cutter
    My harbor freight welding cart is too small for my 225LX. So I decided to build my own. I had some 1" Steel Square tubing left over from bracing the legs on my welding table. May as well use it to build my cart. Heres the base for my cart. Settings used was DC 88amps, 1 sec preflow 2 secs postflow 3/32 lanthanated tungsten 3/32 ERS70S2 fill rod, 8LPM with a gas lense and #7 cup. I still need more practice but I think my welds look pretty good.
    What gauge sheetmetal should I use for the base? 16 gauge?
    I'm almost empty on Argon so I think I'm going to upgrade from a 80cf to a 220 tomorrow.
    Not bad far as the welds go, and a very good choice on the bottle swap. 220 will save you money pretty fast.
    16 gauge is fine on the shelf and you can tack it if you're worried, mine just sit on the rails and never had a problem. I have an IMIG 205P, PP60 and 250EX setting on one cart (three tiers) made of 16 gauge and angle 1.25x1.25x1/8".
    Spent some more time last night on it. Here is where I'm at now.
    I was off to a good start today cutting 16 gauge steel sheet into peices for the welding cart and welding them on...
    Then my Everlast 225LX starting blowing holes through anything it would touch. I had it set at 88amps and it was putting out 350+amps, Blew a hole through my welding cart, amps on the screen said 444 amps.
    Everlast PowerTIG 225LX
    Everlast Power IMIG 200
    Have you figured anything out yet as to what is wrong?
    Power tig 225lx
    Hand tools up the wazoo.
    Yes, I couldn't get ahold of Ray all day so I called and talked to Mike and he diagnosed in over the phone in 5 secs. Alex took care of the issue.
  1. Welding Cart For 250EX And PP60 Plasma Cutter+ Boat Project
    By zoama in forum Other Custom Fabrications
    Last Post: 01-29-2016, 02:55 AM
  2. welding cart/cooler project
    Last Post: 01-05-2012, 01:11 PM
  3. first functional welding project with 225lx
    By revkev6 in forum General Welder Questions
    Last Post: 10-18-2011, 12:39 PM
  5. Home made welding cart and Tig torch water cooler
    By jameswswanson in forum Other Custom Fabrications
    Last Post: 04-20-2011, 08:01 AM
