Results 1 to 4 of 4
Thread: Power Ultra 205P
    Default Power Ultra 205P
    Been having trouble getting the Power Ultra 205P to cut when operating on 120V. Here are the symptoms:
    The machine cycles back and forth between the pilot and cutting arc unless the air pressure is reduced to very low levels, about 45 psi. When its this low, the cut is terrible and it splatters all over.
    The air is clean and the ground connection is solid.
    Oh, and it does have points and they have been adjusted correctly.
    I am going to pick up some 0.6mm, 20 amp tips, to see if this will help.
    Does anyone have any other ideas to try?
    TIA,
    Ken
    __________________________
    Everlast Power I-MIG 200
    Everlast PowerUltra 205P
    Everlast SM 200-N
    Thermal Dynamics Cutmaster 42
    When my electrode got loose inside the torch, it did something similar.
    also, I know you are an electrical wizard, but you are now using your pigtail. When I made my pigtail for 220 at machine to 120 at the wall, I was really careful to get the wiring sequence correct. I think it would be possible to get the 120v wires turned around. Just a guess.
    ken
    ken
    I have tried new electrodes and tips with no change in operation.
    I know the wiring is correct, I run my I-MIG off the same pigtail, and have measured the voltage sag which is almost non-existant.
    Plus my dual voltage Cutmaster 42 works perfectly fine on the 120V branch.
    I am just trying to get it to work satisfactory on 120V so I can use it when on the road...
    Everlast SM 200-N
    Ray, I have PM'd you a few times and sent you an e-mail asking for assistance, can you please get back to me?
    Thanks,
    Ken
    Everlast SM 200-N
  1. Power ultra 205p compressor question.
    By kvr28 in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 01-24-2016, 11:45 PM
  2. Power ultra 205p purchase??
    By Tiberiusx in forum Pre-sales, Sales and Shipping questions
    Last Post: 12-23-2013, 11:09 PM
  3. New to EverLast Looking at a Power Ultra 205
    By Zaichuk in forum Introduce Yourself
    Last Post: 03-28-2011, 12:56 AM
  4. Power Ultra 205 issue
    By turpehar in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 11-20-2009, 05:17 AM
  5. power ultra 205
    By gwk in forum Customer Testimonials
    Last Post: 09-27-2009, 10:58 PM
