Results 1 to 9 of 9
Thread: It Finaly Here!!!
    Default It Finaly Here!!!
    After 3months of waiting including a week sitting at my freight forwarder because it wasn't labeled properly, the delivery man dropped off my Powertig 225lx today. Now i just have to finish up wiring for power, and give the gas man a call. will post picks as soon as i get the chance.
    Everlast PowerTig 225 LX
    Miller Spectrum 375
    M-Tech Model 3 Tube Bender
    JD2 Notch Master Tube Notcher
    Light Racing Dimple Dies
    some pic's. hooked up the power today, gonna fire it up and run it in stick mode tomorrow.
ID:	5957Click image for larger version.
ID:	5958Click image for larger version.
    Miller Spectrum 375
    Well good luck with it... Guam??? I can see where you can have trouble with shipping. Looks like everything arrived intact. Do you do any TIG welding/experienced with TIG??? Have to let us know how you do.
    Shade tree MIG welder.
    Now a Shade tree TIG welder.
    Congratulation on your new TIG. It looks like you have the same foot pedal as I do for my PP205. If so there are screws on the bottom that could get stripped from slidiing it on the ground. A tip I got from Ray (Everlast Support) was to put some rubber boat traction I got at Home Depot on the bottom to raise the screws off the ground and protect them. I added the rubber traction to mine qand have no problem sliding it around and not damaging the screws. Good luck.
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
    Stomper4x4,
    Thanks for hanging in there. They sell out fast but sometimes takes time to re-stock.
    Make sure you pull the latest manual from our website. Red button upper right on all site (not forum) pages. I was not aware the screws were on the bottom on the 256 pedal. Can you confirm this? Things change sometimes. Should be know external adjustments on the pedal.
    Enjoy, post pictures and call us if you have any questions. LX fan though I traded up for the EX.. Great welder.
    The only real trouble with shipping was it wasn't labeled as i instructed, so when ups dropped it off at the freight forwarder they didn't know where to ship it to.
    I have never tig welded not ever, cant wait till i can get some gas to try it out. The gas co. wants $300.00 for the bottle and $150 to fill it.
    Miller Spectrum 375
    Quote Originally Posted by stomper4x4 View Post
    Ouch that seems pretty high. Could be the area. How big of a bottle is it???
    250cf only size they have.
    Miller Spectrum 375
    The refill sounds very high. Should be under $100 for sure. We are high here at $85-$80. Must be location. Good news, the bottle will last a lot longer then the smaller ones. So it's not the end of the world. Make sure you read up on setting the gas flow in Lpm so to not waste gas, that will help too.
