Results 1 to 8 of 8
Thread: First prototype portable flywheel grinding machine
    Default First prototype portable flywheel grinding machine
    Love free time to work on projects. have some funny car racers that gave me some hints on a machine to resurface there clutch plates and floater on the clutch pack units so got down and built a grinder they would like and also was a wet grinder since not so messy and leaves a perfect finish on there floaters with out plates warping . well got 1st design done . post some pics Attachment 6056Click image for larger version.
Name:	engine rebuild and installs 004.jpg
ID:	6057Click image for larger version.
Name:	engine rebuild and installs 005.jpg
ID:	6058Click image for larger version.
Name:	engine rebuild and installs 007.jpg
    Is that what would be called a "blanchard grinder"?
    That looks really useful. I'd probably be turning it into a rotary table milling machine if I had it. Or at least, surfacing a flywheel or pressure plate.
    What X-Y table did you use?
    The table is a big block Chevy flywheel i machined on my lathe and Bridgeport mill , the plate rides on a lower heavy cast iron base that is filled with table oil . the same as a van norman flywheel grinding machine uses that way the table always runs true , put my dial indicator on it when turning has 0 run out reading . table turns at 18 rpm
    rotary table milling yes i think it would be good for that , I have some machine blocks for my cbn head resurfacing machine that are not true would be good to match them up to the same size . be nice to have the table magnetic also
    Looks good. Probably a ton cheaper than the FG4000R we bought late last year. Have you made an adapter to surface the floaters?
    Chris
    Everlast Powertig 200DX
    Miller Synchrowave 200
    Hobart Handler 210MVP
    HTP Microcut 30
    yes a lot cheaper and a lot lighter its weight is only 350 pounds . pressure plate outer bolt holes worked perfect for the location of offset cams to hold the floaters tight and flat on the table . I got a 5000 Van norman grinder its one heavy machine lol
    now i am going to start making a tool post grinder for my lathe . a lot cheaper building one than buying one
    oh i did a parts list of what it took to build the machine all parts totaled just under a 1000 dollars
  2. Optimal Tungsten Grinding Angle
    By Rivets in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 06-11-2012, 08:49 PM
  3. Final portable flywheel grinder after proto type
    By Rodsmachineshop in forum Other Custom Fabrications
    Last Post: 04-09-2012, 06:01 PM
  4. Project #2 from Trip59, grip prototype
    By Trip59 in forum Personal Projects (no welder required)
    Last Post: 09-25-2011, 06:34 PM
  5. Need help finding a brand of grinding disc.
    By A/C Guy in forum General Welding Questions
    Last Post: 04-08-2011, 02:24 AM
