Thread: hand control on tig torch
    Default hand control on tig torch
    Been working on a system to control amps that like a foot peddle so working on a set up you use your thumb like pushing a foot pedal . first proto type . already have the electronicClick image for larger version.
Name:	engine rebuild and installs 003.jpg
ID:	6191Click image for larger version.
Name:	engine rebuild and installs 004.jpg
ID:	6192 part figured out
    Feb 2012
    I was thinking about making something myself with a 47K slide or thumb-wheel potentiometer but they're hard to find in a small enough size in the 1-watt range.
    There are quite a few manufactures making the rotary types and thumb-wheel ones but most are for the larger torch sizes which are quite bulky IMO.
    I'd like to find something compatible with the smaller WP-20 torch like the ones from Uni-Mig or ParWeld.
    http://www.esseti.co.nz/uploads/products/162/files/XA26.pdf
    http://www.parweld.ro/doc/4catalog.pdf
    http://www.powerweldinc.com/files/powerweld/catalog/section3/Parweld Ergo-Tig.pdf
    So what are all the different levers and which one is going to control your amperage settings?
    they have them on ebay they use them in waawaa pedals use a 50k works better
    made a box with the micro switch and potentiometer and it uses a bicycle cable to work the potentiometer
    i dont like thumb wheels used them hard to work with a welding glove. the flat one you push with your thumb but found need to move the lower arms back so not in the way when holding torch. also though maby a gear and and slide so wont have anything stick down under torch. tried hooking to regular pedal and have pull pedal down but spring in pedal is to strong
    Everlast have a WP18 torch available with a rotary control built in. Also a WP26 air cooled (but that is big)
  1. hand amp control help!
    By aaron1 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 06-11-2016, 08:46 PM
  2. Omic Sensor with hand torch?
    Last Post: 08-24-2013, 11:35 PM
  3. hand control
    By hammerbait in forum General Welder Questions
    Last Post: 02-27-2011, 11:11 AM
  4. Torch hand control questions
    Last Post: 08-07-2010, 01:29 PM
  5. PowerTig250EX Torch Control
    By JJW in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 08-05-2009, 02:34 AM
