I do the round corner like that use a cutting torch and at same time heat the metal and tap it with a hammer to shape . plasma cutter is great to to do that but then it turn out better if you heat the metal to form the curve . that cart turn out really cool do like how you did do all the curves on it . I rate it a A+ on fabrication
