Results 1 to 7 of 7
Thread: Consumables
  1. Default Consumables
    What consumables can be purchased at any welding supply dealer that will work with the super200p?
  2. Default Re: Consumables
    The TIG torch is standard. On the electrodes, you need to ask for 1/16", 3/32", etc to match which collet you use of course. Use tungsten for aluminum welding and 2% (red tip) for steel. Some people use 2% for everything.
    On the plasma cutter, you can order them from us or about anyone selling them on the internet as the torch is a standard part between the import welding company torches, the units are different (built to certain company specs) but the torches all come from the same place.
    Our new IGBT line you can pick parts up at your local welding supplier, it will just cost more.
    I buy from PraxAir and Welder Supply when I am in a hurry, otherwise, I get them from Everlast. Google for Praxair or Air Gas and see if you have one near you for the TIG supplies.
    http://www.everlastwelders.com
    http://www.everlastgenerators.com
    Aug 2009
    North of Dallas Tx
    What are the part number/type of the ceramic cups for the tig 200LX? I want to get some size 10-12 and make a diffuser. They had all kinds at the welding store and I should have brought a spare to match but i didn't.
    Gnothi Seauton 515 rwhp/527 Lbs.@21psi....nuff said.
    http://i156.photobucket.com/albums/t...ax_Modsico.jpg
    2JZ-HX40 Turbo swap Conquest. SDS-6E ECU, turbo pistons & HG, ACL race bearings, Arps, Custom FFIM for 1000cc injectors ..E-85 daily driven.
    http://i156.photobucket.com/albums/t...t/DSC01364.jpg
    2009 FZ1N Retro
    PowerTig 200LX to make things possible.
    Quote Originally Posted by Mad-Dax View Post
    Hey Dax,
    Take one with you to the LWS, they can match it up. It would be better take the torch and fit it when there. Then no room for error.
    These are weldcraft WP 18,26 compatible and you can get a gas lens to fit it.
    Aug 2009
    North of Dallas Tx
    What if the part numbers are like 10N22 .040 collet. I see alot of part numbers that are 10Nxx and then it states will fit 17,18,and 26. Thanks guys
    2009 FZ1N Retro
    Our part numbers are probably different, but that does not mean they won't interchange. You simply tell the LWS what Weldcraft torch equivalent you have. Most of the collets and stuff for weldcraft WP series are interchangeable. That is why we use their style and why it is so popular world wide.
  1. Consumables
    By rkinken in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 03-25-2016, 01:57 PM
  2. Where are you getting your consumables?
    By Klr49adv in forum General Welding Questions
    Last Post: 12-04-2013, 05:21 PM
  3. TIG consumables
    By Rambozo in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 08-19-2012, 07:11 PM
  4. New consumables
    Last Post: 01-13-2011, 12:14 AM
  5. Consumables
    By weildkorp in forum Everlast Plasma Cutters (PAC)
    Last Post: 02-23-2010, 08:12 PM
