Thread: Confirm CK prt numbers for water cooled torch?
    Default Confirm CK prt numbers for water cooled torch?
    I've read a few threads with different info. I'm pretty sure I got it sorted out but just want to make sure. Can somebody look at these parts numbers and tell me if they are correct? Thanks!
    CK-225SF FX 250 amp flex haed and super flex cable.
    SLWHAT-35 water cooled dinse 35 connector
    H: PowerTig 250EX
    W: Lincoln Precision Tig 225
    W: MK Products CobraTig 150 orbital welder
    Crap, I forgot about the finger control. I have no idea what to order on that side of things.
    H: PowerTig 250EX
    If your using the foot pedal you wont need to worry about the torch trigger. It is just a 2 pin micro switch anyway.
    I'll be doing auto body repair with it for my first project so I'd like to have the finger control.
    I got a quote on those parts listed from my LWS and they were about $250 after tax, seemed a bit higher than I've seen online.
    H: PowerTig 250EX
    I've been a licensed AutoBody tech for 22 years can't say I have ever used a tig on anything but frames (none unitised) and for that I would use a foot pedal. A mig is really the quickest easiest way to do Autobody welding.
    Quote Originally Posted by burner View Post
    Yeah, I know it's a lot quicker to use mig for auto body work. I won't be doing tons of panels however, just one section of ac inner fender and some floorboard patching. Also I've tig welded way more than I have mig so i'm more comfortable doing that.
    H: PowerTig 250EX
  1. Water cooled torch getting hot?
    By 2horses in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 04-01-2017, 07:29 AM
  2. Using water cooled torch as air cooled?
    By Fusion in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 01-16-2014, 11:08 AM
  3. Change tig torch to a smaller water cooled torch
    Last Post: 09-18-2012, 05:07 PM
  4. water cooled torch
    By D.C. Metal Designs in forum General Welder Questions
    Last Post: 08-11-2010, 05:01 AM
  5. Water cooled torch and cooler
    By WAYNESWORLD in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 09-11-2009, 05:33 PM
