I'm seriously considering a powerplasma 60/70/80 http://www.everlastgenerators.com/fo...s/rolleyes.gif
I am sorta waiting to see if the s45 or similar s75 torch will be available for the bigger cutters as I prefer that to the ones currently pictured with the units. (easier to get accessories and consumables) I notice the 80 also uses what looks to be a more common torch though I don't know the name nor have I seen them at the local shops.
Back to my question about expanded metal...can these new pilot arc models cut expanded metal in a reasonable way? I notice Miller makes a big deal about their 'auto-restart' feature (on the Spectrum 675 Xtreme, which is my current alternate cutter choice) and for sure that is what I need....I can't pause each time I loose the cutting arc and wait. I have seen pilot systems that require that (in fact I think it was an lesser miller spectrum)...you had to let the air pressure drop so the pilot can re-ignite or something but what ever it was it was not good from trying to cut a good line or arc.....
Also are the new powerplasma units pretty decent with the electrical interference? I have CNC equipment running pretty near by and can't have that messing up....and maybe someday if I get really energized I might like to run the cutter by CNC and it would be a bummer if it scrambled the PC. I have enough problems with that as it is, from the main drives on the mill.
