Results 1 to 4 of 4
Thread: MIG conversion Kit
    Default MIG conversion Kit
    I would like to be able to MIG weld with my PP256. Any plans on offering a kit to convert a tig to a mig?
    best bet buy a mig welder . only way if possible would buy a add on wire feeder like the old miller welders but the wire feeder are expensive like 1500 or more and are a pain to adapt if not a miller welder .http://www.millerwelds.com/products/wire_feeders/r-115/ this is basically for a dc stick welder to mig weld . never seen one on a tig welder
    I agree ^...
    See you other post for my comments.
    __________________________
    Everlast Power I-MIG 200
    Everlast PowerUltra 205P
    Everlast SM 200-N
    Thermal Dynamics Cutmaster 42
    Danny,
    MIG welders are wired to produce a constant voltage (CV) where as your TIG/Stick machine is wired to produce a constant current (CC, amps). Search around the forums, and there are a few other good explanations as well. This is also the reason your welder has a main amps knob instead of a main volts knob.
    Cheers
    Mike
    Power Pro 256
  1. Amp conversion
    By pavetim in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 04-05-2016, 12:32 AM
  2. WP-18 Torch Conversion to WP-20HC (high capacity) - 315 A Rated
    By Mikey52 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 04-14-2015, 03:40 AM
  3. MIG conversion Kit
    By DannyB1954 in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 05-29-2012, 09:26 PM
  4. Argon Flow Rate Conversion on Tig Calculator
    Last Post: 01-03-2012, 07:13 PM
  5. Another bead roller conversion
    By Ram48 in forum Other Custom Fabrications
    Last Post: 04-27-2011, 02:24 PM
