Results 1 to 12 of 12
Thread: MIG conversion Kit
    Default MIG conversion Kit
    I would like to be able to MIG weld with my PP256. Any plans on offering a kit to convert a tig to a mig? I know Miller has a wire feeder for cc welders.
    I also have a Lincoln gas powered cv/cc machine. A kit for this would work for me as well.
    Ready Welder had a model that worked with cc power.
    Quote Originally Posted by DannyB1954 View Post
    Have you ever tried a MIG converted TIG? I imagine it would not work very well since the CC and CV topologies are very different in their internal designs. If you do try this, post up what you added/changed and how well it works when compared to the real thing.
    ken
    __________________________
    Everlast Power I-MIG 200
    Everlast PowerUltra 205P
    Everlast SM 200-N
    Thermal Dynamics Cutmaster 42
    Thanks for the info. I went to their web site and the prices were about the same as buying a mig welder. The wire spool sizes also were small, so I imagine the replacement costs would be high, compared to a 12 lb spool.
    better off just buying a regular mig welder
    Quote Originally Posted by kenwhite View Post
    ken
    I have 3 welders now, and was trying to get by without having 4. I have a 110v Lincoln mig which works well up to about 3/16" steel, the PowerPro256, and a 250 amp gas powered Lincoln that can be set for either cc or cv. I was wondering if Everlast had an adapter box for a reasonable cost, as the ones by other manufacturers seem to cost as much as a new mig welder.
    On the Everlast sales web page they list wire feeders as coming soon
    how many amps is the 110v Lincoln mig
    Maybe sell the 110vac machine and get an Everlast IMIG-200. Lots of power and small. You can handle sheet metals to 1/4" or so. Just add a 220vac plug and go (about the size of a weldpac or smaller). And I would imagine you can get a fair price for the name as well so the cost would not be bad.
    Just a thought.
    I have an old CK 110vac MIG I'm getting rid of. A gift I thought I would use, like you, no room for one more. And the IMIG-200 covers that base (welding range) pretty well for me (or I will TIG it).
    It is a Lincoln SP-125. I believe 90 amps
    Just a thought.
    I seem to have a problem when it comes to shopping for a new welder. I keep looking at the next model up, and then the next model up. I always worry that I will buy something and then end up wishing I would have spent a bit more for something better. I bought the PP256 recently, so when my bank balance recovers a bit, maybe I will get a I-mig 205P
    Danny,
    Those two units will get you all the things you need on a single phase 50 amp 220vac circuit. Plasma, DC TIG, AC TIG, stick x2 and 210amp plus of MIG. Water cooler and tanks and you have a complete welding shop.
    Danny,
    I bought the Everlast water cooler with the PP256. Have a CO2/argon, (from my little MIG), and a argon tank that I bought for the PP256. Just need to get some more green stuff, (cash and Everlast).
  1. Amp conversion
    By pavetim in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 04-05-2016, 12:32 AM
  2. WP-18 Torch Conversion to WP-20HC (high capacity) - 315 A Rated
    By Mikey52 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 04-14-2015, 03:40 AM
  3. MIG conversion Kit
    By DannyB1954 in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 05-08-2012, 12:26 PM
  4. Argon Flow Rate Conversion on Tig Calculator
    Last Post: 01-03-2012, 07:13 PM
  5. Another bead roller conversion
    By Ram48 in forum Other Custom Fabrications
    Last Post: 04-27-2011, 02:24 PM
