Results 1 to 2 of 2
Thread: Project 3 from KSmith. Category: Custom Shop Tools – Band Saw Stand
    Default Project 3 from KSmith. Category: Custom Shop Tools – Band Saw Stand
    The Harbor Freight 4X6 Horizontal/Vertical Band Saw comes with a stand that is too low, and in my opinion, not built strong enough for the heavy saw it is supporting. I turned the original stand into a smallish storage shelf, and built a new stand.
    Dimensions:
    Length: 35”
    Height: 29”
    Width: 22”
    Step cutout for motor clearance: 8” deep
    Materials:
    1-1/2”x1/8” square tube
    1-1/2”x3”x1/8” rectangular tube
    3” swivel locking casters
    I welded the stand with stick. Four short sections of 1-1/2”x1/8” square tube were welded like wings to support the saw. A space was made for the motor when positioned vertically, allowing the saw to be forward on the stand, for better center of gravity.
ID:	6614Click image for larger version.
    Six tabs made from 1”x1/8” angle were cut as standoff mounts for the saw. Two on each side, and one each front and back. I drilled these for the mounting bolts, and bolted them with enough slack that they could be moved by hand. I hoisted the saw on a strap and positioned the tabs where I wanted them. I tacked the tabs, and removed the saw, so I could finish the welds. I finished the stand in gloss Rustoleum Black, for easier cleanup. (the square tube leaning on the saw is not part of the stand, but some stock I was going to use for my first cut test).
    I tacked two short pieces of 1" angle, to the underside of the saw mount 'wings', to accept a large cookie sheet for saw swarf collection.
ID:	6616Click image for larger version.
ID:	6617Click image for larger version.
    The four casters are great. I can move the saw anywhere and slide it into any corner. I never use the caster locks, the stand is stabile on its own.
    The original stand is now a shelf. Notice the spindly plastic wheels that came with the saw.
ID:	6619Click image for larger version.
    ken
    I did something similar, except I added angle down each corner of the original legs and welded a bracket for heavy rubber wheels so the saw can be picked up and rolled over gravel. I'll post pictures tonight if you'd like to see my take on it. I like your design though; any plans for adding a coolant pump/reservoir for the blade? Makes a huge difference in noise and blade life when it's lubricated and kept at a decent temp. Simplest designs I've seen take a HF fountain pump, water-soluble cutting fluid, some tubing, a bucket, and a nozzle. Just don't forget to add a sieve at the top of the bucket to filter out debris/chips as those will kill your pump.
    Power I-MIG 250 P
    Lincoln Weld Pak 100
    Miller Digital Elite welding helmet
    More leather clothing than a sex shop
    HF 7x8 Lathe (14" bed, AXA QCTP, 5 inch chuck, other mods...)
    HF Mini-Mill (Converted to ballscrews/CNC)
  1. Project 1 from EmptyNester. Category: Custom Shop Tools - CNC Table
    Last Post: 03-11-2013, 12:27 AM
  2. Replies: 12
  3. Replies: 28
    Last Post: 12-26-2012, 03:01 AM
  4. Replies: 18
    Last Post: 09-07-2012, 07:46 PM
  5. Replies: 12
    Last Post: 07-19-2012, 09:03 PM
