Thread: Project 5 Mean Green Contest, SeanMurphy265, Mobile Home Leaf Spring Mounts
    Default Project 5 Mean Green Contest, SeanMurphy265, Mobile Home Leaf Spring Mounts
    This is the third time I have worked for this guy, so I'm getting use to crawling under mobile homes. This one was foreclosed by the lender. When they backed it originally they got the house in a bind, and bent some of the mounts and the main beam that runs under the home. I cut all the leaf spring mounts out and tried to grind them the best I could. I cut out twelve in all, and welded the new ones in place. The original mounts were way too tall and that's not good when your hauling them down the road. Did this with my Power Arc 200, grinder, and torch! I did weld some support on the tongue also.
    You can see they bent them.
    One of the cut out brackets.
    New mounts.
    I guess I was in a hurry, pics blurry, welded bracket multiple passes 7018.
    Interesting project. I guess I never really thought about the suspension requirements on a mobile home.
    - Dr. AR Dykes
    Need to build a mobile home DolleyClick image for larger version.
ID:	6820Click image for larger version.
ID:	6821Click image for larger version.
ID:	6822 set up
    Lol!!! If I did that then I would not have the welding business! For some reason all the manufacturers build different tongues with different mounting locations. You would think they would all go to some type of industry standard to lower their cost.
  1. Mean Green Spring Contest March 16 -June15 (11:59 pm)
    Last Post: 05-23-2013, 07:25 PM
  2. Questions and comments for mean green spring contest
    Last Post: 02-10-2013, 01:12 PM
  3. Project 6 Welding Table, Mean Green Contest, SeanMurphy265
    By SeanMurphy265 in forum Other Custom Fabrications
    Last Post: 06-09-2012, 02:41 AM
  4. Project 4 Mean Green Contest, SeanMurphy265, Stage Backdrop.
    Last Post: 05-11-2012, 05:51 PM
  5. Mobile Home Trailer Project 3 Mean Green Contest
    By SeanMurphy265 in forum Heavy Equipment and Commercial Projects
    Last Post: 04-06-2012, 10:28 PM
