Results 1 to 20 of 34
Thread: Plasma tracing tool
Rodsmachineshop Plasma tracing tool 06-03-2012, 10:17 PM
undercut Looks like you are making... 06-03-2012, 11:08 PM
Rodsmachineshop yes 1 to 1 . yes circles came... 06-03-2012, 11:19 PM
undercut Good implementation. ... 06-03-2012, 11:44 PM
Rodsmachineshop Pantograph i copied worked... 06-04-2012, 12:08 AM
NRM Rod do you know why your... 06-04-2012, 01:25 AM
Rodsmachineshop I didn't like it wasn't... 06-04-2012, 01:40 AM
undercut It has to do with the lengths... 06-04-2012, 03:35 AM
Winky Thanks for posting this link... 06-04-2012, 12:33 PM
Rodsmachineshop well played with the tracer... 06-04-2012, 04:14 PM
undercut You are very welcome, Winky. ... 06-04-2012, 04:26 PM
NRM I don't have a need for a... 06-04-2012, 04:55 PM
undercut I'm with you there. I was... 06-04-2012, 07:13 PM
Rodsmachineshop replaced cross bar to round 1... 06-04-2012, 09:00 PM
undercut Good observation. I never... 06-04-2012, 09:26 PM
hokiefd Same here, lol. I never even... 06-04-2012, 10:55 PM
Winky I would like to see this in... 06-04-2012, 02:51 AM
    Thanks for posting this link ... http://en.wikipedia.org/wiki/Pantograph ... it explains some things I was wondering about ... maybe I'll try to build one myself.
    Powertig 200DX
    Lincoln 180c
    Hobart Handler 125
    and a bunch of other tools
    well played with the tracer last night and found going to use 1 inch round instead of box since slides with no bearing fixture drag a all for the shorter cross section and for the box that the torch is attached to going to use aluminum since lighter . called my steel supplier and order a 20 foot piece of 1 inch .125 wall aluminum box . not bad priced was only 35 bucks for a aluminum 20' x 1x1 box .125 wall .
    You are very welcome, Winky. Just watch for any play in the pivots as that will kill any chance of the duplicate looking like the original!
    Also, you might want to experiment and figure out whether you want one of the arms extendable to allow you to reduce, enlarge or make 1:1 your copy.
    Remove any drag and you'll be king!
    I don't have a need for a pantograph, but now I want one. Keep posting pics and your progress.
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
    I'm with you there. I was thinking about all of the things I could do just driving in to work this morning! Mind you, I would need to buy a plasma cutter so that might be a ways away. After the pantograph, a CNC!
    It's lunch time for me now. Also thinking about some crispy skinned pork .....
    replaced cross bar to round 1 inch 120 wall big difference can blow on it and it moves , did a micrometer check on the box and on the round tubing . the box has a a lot of difference in thickness, round is true all the way from end to end . when building mt cnc table will use round tubing also noticed round is better on not flexing like box tubing. so 2 inch 120 wall would be great for rails for a cnc table for gantry to run on .Click image for larger version.
Name:	engine rebuild and installs 004.jpg
ID:	6957Click image for larger version.
Name:	engine rebuild and installs 005.jpg
ID:	6958Click image for larger version.
Name:	engine rebuild and installs 006.jpg
    Good observation. I never would have initially thought to check the thickness of it. Weird how we take some things for granted. Good that you caught this here before you got too far on your CNC.
    what good 120 wall tubing is very cheap
    Same here, lol. I never even thought about it until finding this forum.
    There are some neat rigs for routers too:
    http://www.youtube.com/watch?v=2lKNG...D63FF280901729
    - Dr. AR Dykes
  1. new tool i bought
    By Rodsmachineshop in forum Tips & Tricks, Custom Tools, Safety, Ideas and Reviews.
    Last Post: 06-15-2012, 12:24 AM
  2. Northern Tool Mig Welder
    Last Post: 06-12-2012, 03:16 AM
  3. Dimple die/punch tool
    By acourtjester in forum Off Road Fabrication
    Last Post: 10-07-2011, 03:20 AM
  4. Cutting - am I using the wrong tool?
    By bricot in forum General Welding Questions
    Last Post: 10-07-2011, 01:44 AM
