Results 1 to 9 of 9
Thread: Project 6 Welding Table, Mean Green Contest, SeanMurphy265
SeanMurphy265 Project 6 Welding Table, Mean... 06-08-2012, 01:14 AM
KSmith The only thing I see that I... 06-08-2012, 01:46 AM
SeanMurphy265 The top plate is tacked on... 06-08-2012, 02:44 AM
KSmith Sean, if you are worried... 06-08-2012, 03:34 AM
SeanMurphy265 I've been looking into one of... 06-08-2012, 11:51 AM
    Default Project 6 Welding Table, Mean Green Contest, SeanMurphy265
    Picked up this 3'x4'x3/8" piece of plate at the local steel supply for $110.00. Decided that I would build a welding table with it. The table frame is 1-1/2" square tube 1/8" thick. Started on it yesterday evening, and I have a few more braces to add along with some wheels.
    That plate was a little heavy to lift by myself. I need an engine hoist! The table is 3' high; I have had back problems so I do not like being hunched over when I'm working. I'm 6'2" so the height is good for me.
    Using my plasma table to square things up.
    Bottom rail squared up and tacked. I then slid the plate from my Blazer to the top of the frame.
    Making sure their is not bow or sag in the plate. Some of the tube had a slight bend from transportation. My next project is a rack for my blazer.
    I'm going to add some 45 degree braces along the bottom to keep the legs from getting bent.
    The only thing I see that I would have suggested, but too late now - On mine I put a couple inches of overhang of the table top all around, for the use of clamps. I like to use simple spring clamps whenever I can. You will be limited to large c-clamps or bar clamps that spread to include the 1-1/2" tube. It will work ok...just wanted to mention.
    ken
    The top plate is tacked on for right now. I'm looking at two options in the future. To cut slots with my CNC plasma table when I finish it up, or get a mag drill and put some holes in it. I was afraid that I could bow the plate if I put a lot of pressure on it, that's why I went all the way to the end. I built the table because I am tired of laying stuff out on the ground and trying to keep it square.
    Sean, if you are worried about bowing you could put another square tube below across the midsection, and tack it to the table top for extra strengthening. The holes in the plate for fabrication clamps will work great.
    ken
    I've been looking into one of these mag drills. I'm not sure how much I would use one, but it would give me the capacity to drill large holes.
    I don't have a mag drill. On my table I still want to drill a series of holes for screw-in clamps. I will drill and thread the holes 3/8, as perpendicular as I can with a 1/2" chuck drill. I will build a little slop in the little clamp, that the bolt will press against the work, so that it will face the work square in the end. For large holes I think using the plasma to pierce is a decent way. I have a set of these demming bits too, up to 1". http://www.harborfreight.com/8-piece...t-set-527.html Pierce with the plasma cutter, then clean out with the demming bit. A bit rough but is do-able.
    ken
  1. seanmurphy265 Project 3 Almost Summer contest - Condenser Rack
    By SeanMurphy265 in forum Heavy Equipment and Commercial Projects
    Last Post: 10-10-2012, 03:55 AM
  2. SeanMurphy265 Project 2 Almost Summer Contest - Tube Bender
    By SeanMurphy265 in forum Other Custom Fabrications
    Last Post: 08-24-2012, 05:05 PM
  3. Project 5 Mean Green Contest, SeanMurphy265, Mobile Home Leaf Spring Mounts
    Last Post: 05-23-2012, 01:26 AM
  4. Project 4 Mean Green Contest, SeanMurphy265, Stage Backdrop.
    Last Post: 05-11-2012, 05:51 PM
  5. Replies: 4
    Last Post: 03-31-2012, 10:01 PM
