i do a variety of work. recently was asked to install these windows in an older retired naval vessel that is used at an area port.
take note of my field plasma cutter for cutting the radii.
windows/ install and weld
install and weld. welded out with xmt 350 inverter and 30 spool gun using .035 wire. skin was only .10 thk, angle frame to seat windows on was 2 x 3 .25.
i am nearly always out in the field.
A sunroof for an old patrol boat?
I didn't think you could get a nice radius cut with a saw like that. .10” seems thin but maybe the ribs make the top ridged.
PowerPro 205
9" South Bend Lathe
Enco Mill/Drill
ships moored outside the port frequently have passengers/staff etc that need to be picked up or returned. there is generally a ladder that extends down the side of a ship that they use to debark. if you are inside at the helm, the windows allow you to look up while you are positioning the boat at the base of the ladder. they are a visual aid.
Nice work and I love old naval vessels...
__________________________
Everlast Power I-MIG 200
Everlast PowerUltra 205P
Everlast SM 200-N
Thermal Dynamics Cutmaster 42
