Results 1 to 16 of 16
Thread: i-mig 205 question
    Default i-mig 205 question
    I just got my 205 hooked up and running and aside from my regulator having a small pin hole in it it welded very nice but i didnt want to run it to much and waste the gas from the leak,my question is what is the thickest material someone has sussefully welded and what is the longest weld someone has ran on this machine without duty cycle being a problem,just trying to get a good idea of what i am going to be able to do with this machine?
    have them send you a new regulator , the thickest i have weld so far with my 205 is 1/2 steel took 2 pass with 35 wire . as for duty cycle don't think you will ever get there . I welded 1/4 plate one day for about a hour and never stopped from reaching duty cycle turn off
    Well you can run it wide open for 3.5 minutes out of a 10 minute period without stopping. My Dad worked for a LWS and they had a customer who thought they were bumping the duty cycle on their machines (Steel building mfg). They came in and timed the welders without them knowing what they were doing. They did this for a week and no welder welded long enough to bump the duty cycle. No one ever welded over a minute straight, and I think 45-50 seconds was the longest anyone welded without stopping.
    yes as for welding and hour like i posted i took breaks to align stuff . so it was not a constant 1 hour of welding
    Doggone ya dun went and spoiled ma picture of an 80 foot long constant bead. Name:  hehee[1].gif
    I already talked to alex about the regulator and they are shipping me a new 1 out today so hopefully it will be in this week.I already have a job set-up for my mig machine so its time for this machine to start paying for itself .
    If you only have the one tank and regulator, might want to look at the Clarke clones Harbor Freight has. I want to say it was under $30 with the 20% off coupon way back when. Small price to pay if you loose a regulator and you can be up and working today while waiting on ours to get there. Just a thought as they can get broken with the pressures they are under or they get knocked..
    i might be buying a smith from a friend of mine for 40.00 ,its brand new so i dont think i go wrong on that 1.have you ever seen 1 of these everlast regulators with a pin hole in it?I have the 250ex and didnt have problems with it.
    Smith is a good one. Sometime I hear of hairline cracks from over tightening. I have 5 in use and been lucky, never had a leak. Did have a hose blow off once.
    next toy i want is a plasma cutter ,any suggestions?
    I like the PowerPlasma 50 myself. What is the max thickness you are cutting also, much much cutting a day? I use a PP60, but switching back to a PP50 since it a bit is smaller (in weight and size).
    I think the PP50 is where I would start. I have the Super Cut 50 and it's a good entry level plasma cutter, but it's limited in duty cycle. The PP50 will give you some growth potential with a CNC port, and it's a heavier duty plasma cutter than a SC50. I have no issues with cut ability of my SC50, and I use it for sheet metal so I never have any issues. I cut some 5/8" bars out of a smoker for a guy back in the spring. I gouged out the welds because I needed it to look good, but I had to stop and let the cutter rest because of the duty cycle. If you hardly ever use a Plasma cutter then I might look at a SC50 (I use my plasma cutter once or twice a month), but I would start out with at least a PP50 you will be happy in the long run.
    I have had both plasma cutters the power plasma 50 is the one to get night and day difference on how they cut . power plasma 50 comes with a better torch also and consumables last longer
    You are talking about the SC50 and PP50 of course. I mentioned the PP50 and PP60 (I think) in my post.
    But again, the PP50 is a favorite, I am waiting on another one right now. I get them, and people have to have them.
    yes the SC50 and PP50 have the pp50 now with The IGBT technology and cnc plug on back like the s45 torch cuts better don't like the 60ACPA torch eats consumables == i stay away from the mossfet units . another nice unit if want to do dc tig and have a nice plasma cutter is the PowerUltra 250P neat little welder
    One thing I have figured out after getting the PP70 (A81 torch), it's best to get the amperage close to what you will be cutting the most. The smallest tips for the 70 amp plasma is 1.0mm. For 19 gauge sheet metal, the .6 or .7 tip on the Matco plasma cuts cleaner. I think I will get another torch in a smaller amperage for thin metal.
    The PP70 is 100 times better machine, but the tip is just too big for thin stuff.
