Results 1 to 3 of 3
Thread: "60 Amp" torch on PP50?
    Default "60 Amp" torch on PP50?
    I've started building a plasma table.
    I was interesting in getting a machine torch (straight/inline torch). The only ones I found are listed as 60 Amp torches. Will they work okay on a PP50?
    I'm guessing it would also have to support pilot arc to work properly?
    From a cost viewpoint - I'll go with the S45 torch for now, but would like to know if I can move to a more appropriate torch.
    Anybody have any experience with that?
    Just starting in Aug '10
    Hobart Handler 187
    No, it won't work, not ours. You have to find a comparable blow back style start. The 60 amps are HF. Big difference.
    You need either an S53 or S75 trafimet.
    Hey Mark,
    A quick web search didn't show anything for S53 and the S75 looks like the same style as my S45.
    Thanks,
    Rege
    Hobart Handler 187
  2. "new! 15 ft. 17 series finger amp control torch. Check availability."
    Last Post: 12-30-2013, 11:30 PM
  3. Replies: 11
  4. Cutting 3"x3"x3/16" Angle
