Results 1 to 20 of 24
Thread: Cutting with no eye protection...
    Default Cutting with no eye protection...
    So my helmet goes to shade #9 but that is too dark for some cuts.
    I drew out some flames the other day on a sheet of Aluminum and had to cut them with no eye protection on so I could see the lines. not good, especially when my eyes are bad anyway.
    Do they sell goggles in shades of .. 5, 6, 7 to use with Plasma cutting?
    Dummy....you need eyes to clean a pool....
    from hypertherm
    Less than 40 amps.......shade 5
    41-60 amps..................shade 6
    61-300 amps................shade 8
    http://www.eastwood.com/plasma-shade...FQhN4AodkHEAUQ
    http://store.cyberweld.com/misaglsh5lew1.html
    I bought some wrap around sunglasses in shade 5 from Zink Safety , They work good for cutting and grinding.
    PowerTig 200DX
    Supercut 50P
    Millermatic 200
    Jet 1340 Lathe
    Jet 20" Drill Press
    Jet 12" Wet Band Saw
    Kalamazoo H7 Bandsaw
    Forward 12,000 lb 4 Post Lift
    I use a face shield that supposedly has a shade 5 shield for cutting. Use a mechanics light if you can’t see that has helped me before.
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
    from hypertherm
    Thanks for the link, I like the Eastwood glasses... I Do Not suggest using a plasma cutter with no eye protection, I learned the stupid way
    Having only one eye to begin with I take as few chances as possible ... when cutting I use a #9 but I bring out as much light as possible ... I use halogen spot lights or set up outside in the sun ... honest it works ... can see my outline and have good protection. The only time I don't use shade is when I'm coloring with acetylene and O2 even then I use shade till I have the flame set so it's not overly bright ... if I shade while doing the actual coloring I can't get the proper effect.
    Powertig 200DX
    Lincoln 180c
    Hobart Handler 125
    and a bunch of other tools
    yes there goggles use for gas welding . i use my gas goggle when using plasma number 6 lence http://www.ebay.com/itm/Welders-Gogg...item3a6a5f5de5
    I have several pairs of these "OTG" glasses which are great if you wear normal eyeglasses. They fit over normal eyewear and are available in different shades. Here's a link but be apprised, I have never ordered from this place. Only providing the link so you can see the product. http://www.envirosafetyproducts.com/...-shade5.0.html
    I find these safety glasses to be very strong and do not scratch if you treat them with some care.
    Quote Originally Posted by Ray C View Post
    Thanks for the link!
    That's a great idea, Winky. I was trying to get out of the heat over the weekend so I figured I'd resume welding after dinner. Good plan except while it is fine seeing the arc when it is lit, can't see enough of the material to start a good arc when the sun starts to go down! I'm going to get a spot light.
    I like the link from Ray C. Am also looking for some safety glasses that fit better over my prescriptions.
    Good thread. Thanks everyone.
    The LWS here had a face shield that was either 5 or 6, so I got it and couldn't be happier. No problems seeing the lines, especially in the daylight, and doesn't interfere with glasses either. I don't recall how much I paid, but it really wasn't out of line for a Huntsman.
    Jackson has the same thing down here. #5 and #6 we have at the LWS and full face, they are nice. I have a friend that uses it for light MIG. They are about $22 for the Jackson. #5 is good for cutting and grinding (cutting=plasma)
    I went to my LWS and they are ordering some OTG safety glasses for me.
    I could probably get them cheaper online but these guys take care of me on gas and filler rods so it all equals out..
    I have only used a plasma cutter a handful of times but have never used any shades.... after reading this I am guessing I probably should have.... Would standard sunglasses provide enough protection or should I invest in goggles?
    Shane
    Everlast PowerTig 200DX
    Everlast Supercut 50P
    Shane
    Pick up some number 5 shades. You need them, sunglasses are not enough.
    Will do... actually I may already have some goggles that came with a acetylene torch (not shore of the shade...). A good pair of goggles are cheaper than a new set of eyes...
    Shane
    Shane
    That's for sure on the eyes. The O/A set will work fine (probably a 4-5), they are a little less comfortable than the sun glass wrap around type.
    Another option is a full face shield and use it for O/A. plasma cutting and grinding with better skin and flying parts protection..
    I only use genuine willy wonka plasma cutting goggles .Click image for larger version.
    Feb 2012
    Wouldn't an auto darkening helmet that has adjustable shade control from 6 to 13 work well for plasma cutting?
    It could. 6 might be a little dark for some people. The grind mode of many are about 4 which can work, too, but is a little light, for most. How bright your surroundings are have an effect, too. Everyone is a little different. However, the helmets that have cutting modes to go from 3 or 4 to 8 or 9 will cover whatever you need. That's the great thing about adjustable shades. No more mixing sunglasses with #5 shaded face shield to get it just a little bit darker for some bright O/A work.
  1. Arm protection against welding (tig) sleeves
    By Frank in forum Tips & Tricks, Custom Tools, Safety, Ideas and Reviews.
    Last Post: 06-28-2014, 01:28 PM
  2. Protection against a dust
    By donor76 in forum General Welding Questions
    Last Post: 03-21-2012, 06:37 PM
  3. DIY dryer for plasma cutting and TIG welding. Dross cutting or TIG electrode fur
    Last Post: 03-15-2012, 01:08 PM
  4. Power Surge Protection ?
    By Rivets in forum General Welder Questions
    Last Post: 04-13-2011, 06:31 AM
  5. Protection light on PT225LX
    Last Post: 04-08-2011, 03:39 AM
