Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
Thread: Hybrid Welding Cart Phase 1, Project 1 In Progress
  1. Default
    cbmkr,
    I really like your cart. Nice design and love the way the little one on the bottom comes out like R2D2.
    I found my note pad in the shop today this was the first and only sketch i did, I just don't use cad anymore i have done to many drawings over the years.Click image for larger version.
    ]Well i have finished with my cart, i added many other options to a standard cart design that i needed for my use. The cart was built from 2x2x.200 aluminum angle and .100 sheet, I added a drawer and got it functional.The next step was to make the plasma portable also for the simple reason it will go places like outside.I added a fold up door combo ramp and a couple of magnetic catches to hold the door closed. A little cart was fabricated from some angle and a couple of pneumatic tries i had and 2 casters added a removable handle to pull it around outside.I added some .060 6061 tubes to hold small amounts of filler rod on the cart. The to 2 angles on each rear upright were notched to make a place to hang the torch and the cord. I had a couple of SS Steel coated hooks with wood thread on them removed that and threaded them 3/8" -16 to hang cables on.My cost is less than $65.00 as the aluminum sheet and angle came from the scrap dealer.Attachment 7620Attachment 7621Attachment 7622Attachment 7623
    PowerTig 200DX
    Supercut 50P
    Millermatic 200
    Jet 1340 Lathe
    Jet 20" Drill Press
    Jet 12" Wet Band Saw
    Kalamazoo H7 Bandsaw
    Forward 12,000 lb 4 Post Lift
  1. First Project: Welding Cart
    By Glassbeaver in forum Other Custom Fabrications
    Last Post: 06-19-2014, 04:51 AM
  2. Yet another welding cart project!
    By HemiRod23 in forum Other Custom Fabrications
    Last Post: 06-26-2013, 09:10 PM
  3. Project #3 Another another Welding Cart
    Last Post: 02-17-2012, 07:22 AM
  5. Tig cart in progress
    By 91TSiGuy in forum Other Custom Fabrications
    Last Post: 04-27-2010, 01:52 AM
