Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
Thread: Project 1 from ShaneJackson. Category: Welding Cart
    Tweet #4 (this weeks tweet):
    https://twitter.com/Shane_Jackson/st...91651310428162
    A little less than 4 weeks left on the contest. Been very busy and not had time to work on the cart yet... kind of a good thing since I ended up buying a SuperCut 50P. Now I can build the cart for 2. Back to work....
    Everlast PowerTig 200DX
    Everlast Supercut 50P
    And finally tweet # 5 :
    https://twitter.com/Shane_Jackson/st...91695207530496
    Hopefully I will be able to save up enough to buy a 200DX.... I have already listed 2 of my Fluke 87's on ebay and my Poly-Metric OMF faceting machine (I haven't had time to cut a stone in years...) I hate to sell the OMF but I never have time and haven't used it much anyways. I know I am going to miss it... you can cut some awesome stones with it.
    Then again, if I win 1 or 2nd... 200DX here I come. So far I have 9 entries (need to build a welding cart to make it 10...). Must figure out how to get those final 2 entries.
    Ok need a little input. I FINALLY have everything together to start the build (I think - 2" angle). But I want to run these numbers by everyone to get some input on the size.
    I was planning on going with a 1'x3' wide base. I am basing this off the measurements for a 200DX = 20.2Lx8.6Wx15.5H in. or if I were the lucky 1st place I would go with a 210ext at 19.3Lx9.5Wx18.5H in. (is that height correct???)
    Based on the height and the 2" lip I was planing on putting the top at 24" That would give me enough room for a 3.5" drawer in the future. The wheels sit approx 6" off the ground... So the top would be at approx 30" from the floor.....
    However I was thinking, since I will be putting my plasma cutter on here maybe I should go with a 3 level... I would need to put the second level at 20" high and do away with the drawer idea.... The add a top at 16" above the second (Supercut 50P is 11.5" tall). That would give me a top at approx 42" high.
    Also should I make it 4 wheel or 2 wheel and legs on the front....
    Any thoughts???
    Any thoughts???
    Another option is to go wider and do the side by side setup. A lot depends on where you will park it, does it need to fit under something, what size and number of gas bottles, cable/torch lengths, etc. One thing I've always liked to have mounted on a welding cart is a small Halon fire extinguisher.
    Where do you get those now? I thought the ozone huggers had them outlawed.
    People get them all the time. It is favored in computer/server rooms as well.
    Sep 2011
    Middleburg Florida
    That stuff scares me... I used to fear security checks in the server rooms more than the dark, deserted manufacturing floor in the middle of the night when I did security work. I do have to ask though, would it be effective in any area with any sort of wind or breeze? Wouldn't a small dump like valve on an argon bottle be cheaper and easier to refill? Or a CO2 for that matter?
    Trip Bauer
    Former USN HT
    Everlast 200DX New Model
    Hobart Handler 125 MIG
    Van Norman #12
    Atlas 12" engine lathe
  8. #28
    Well yesterday and today I broke bad and built my welding cart. My wife was a little pissed as I put off having an appraisal done today so I could get this done. Refinancing the house to lower the interest rate.
    I used my PA140ST in TIG mode. I was using a 3/32 2% thoriated with a #5 cap. Amperage was 100 - 120. Filler rod was a 1/16 ER70S2. The metal used was 2x2 1/8 angle, 1x2 1/16 box, and .50" black iron tubing and 2" nipples. Wheels are Harbor freight 10" $4 tires. Bolts (axles) are 5/8 x 5". I also used my Strong Hand WAC35D. It made the build a lot easier.
    I ended up building it 1x3 and the space between the top and bottom is 20" . The back area for the bottle is 1x1 so It can hold a 330.
ID:	8169Click image for larger version.
ID:	8170Click image for larger version.
ID:	8171Click image for larger version.
ID:	8164Click image for larger version.
ID:	8168Click image for larger version.
ID:	8163Click image for larger version.
ID:	8167Click image for larger version.
ID:	8166Click image for larger version.
    I left the 1x2 flooring loose for now. I may tack it later.. The hardest part was putting on the handle. Well actually tacking it. Had I had a mig it would have been easy, with a tig it was a little tricky. Now I have to decide on the paint.... I am thinking GREEN would look nice. Oh and I need a nice new welder to put on the bottom.
    Back to work on the house... before my wife beats me.
  1. Replies: 28
    Last Post: 12-10-2012, 01:21 AM
  2. Project 2 from ShaneJackson. Category: General Welding repair
    By ShaneJackson in forum Welding Repairs
    Last Post: 09-01-2012, 07:15 PM
  3. Project 1 from KSmith. Category: Welding Cart
    Last Post: 04-27-2012, 10:54 PM
  4. Project 1 from CGCINC. Category: MIG Welding Cart
    Last Post: 04-12-2012, 09:21 PM
  5. Project 1 Dyethor, Category; Welding cart.
    By dyethor in forum Other Custom Fabrications
    Last Post: 03-16-2012, 04:55 PM
