Thread: Building a burner for a gas grill
    Default Building a burner for a gas grill
    I can't find the article about building the burner I saw yesterday. However the holes in the burner was not mentioned in the article. Can anyone tell me what size drill bit they use along the burner for the gas to come out for a good blue flame? Thanks Mickey
    Trickbiker
    Click this link for lots of articals> http://www.google.com/#hl=en&sclient...w=1920&bih=932
    I got the information to build mine from here http://www.burnersinc.com/pipeburners/pipeburnerfaq.pdf. Mine are 1" black pipe x 52" with 48" of burner, using a 2"x1" bell for the venturi, with ~120 1/8" holes spaced at 3/4". In the end you will have to play with the gas output distance in the venture to get the best blue flame as it is a mix of propane and air. I will post picks if you want.
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
    You could also do something like this . http://bit.ly/RxanYn
    I don't think it will do me much good over what you have shown me so far. I will have to play with it like you said because of pipe length, orifece size and burner hole size. I will have to work with the orifice hole drilled to the burner holes to get my best blue frame. Is your burner 48" long with holes in it? Thanks for your time and will post some pic and info about it when I'm happy with the results. Thanks again, Mickey
    Trickbiker
    Mickey - Yes my burner length is 48" long. I had to play with the orfice distance in the bell (venturi) to get the flame just right. I started with one line of holes the added another later after playing with it. I use a high pressure regulator with a #56 orfice. Good luck
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
  1. Pig roaster and bbq grill build
    By melman680 in forum Other Custom Fabrications
    Last Post: 06-02-2014, 04:25 AM
  2. Reil Burner (Oxide00 Project #2)
    Last Post: 07-19-2011, 04:31 AM
  3. BIG FAT Bar B Que Grill II
    By performance in forum Other Custom Fabrications
    Last Post: 07-14-2011, 09:10 PM
  4. Another mobile grill project
    Last Post: 07-08-2011, 02:10 PM
  5. BIG FAT Bar B QUE grill
    Last Post: 04-30-2011, 05:13 PM
