Results 1 to 11 of 11
Thread: Motorguard Filters
In Utopia Motorguard Filters 09-23-2012, 07:45 PM
zoama JLMM-45 is what you want.... 09-23-2012, 09:23 PM
nick54 Not intending to jack your... 09-23-2012, 09:24 PM
In Utopia Use a 9/16" wrench on the... 09-23-2012, 10:59 PM
nick54 Thanks for the instructions,... 09-24-2012, 02:23 AM
Rambozo http://bit.ly/NLBtee 09-24-2012, 03:20 AM
nick54 Google, damn, imaging that -... 09-25-2012, 01:30 AM
ShaneJackson Don't know if anyone else has... 09-24-2012, 12:09 AM
Steve Any food that is cooked in... 10-19-2012, 09:51 PM
bnun12 Shane I think your avatar... 09-24-2012, 12:43 AM
In Utopia Just ordered the Motorguard,... 09-24-2012, 11:43 AM
    Aug 2012
    Utopia/Pasadena, TX
    Default Motorguard Filters
    I've been looking at upgrading my present dryer to a Motorguard.
    I notice there are 2 models, a JLMM-45, and a M-26.
    What are the pros and cons of both since I can't find any feedback info on either, and really can't find much general info at all.
    What sort of indicator if any is there to tell when a filter needs changing?
    Right now I'm using HF in lines and putting the desiccant in a toaster oven to dry it out, but even with 28% humidity they are starting to turn pink after cutting out about 12 5" diam. five point stars.
    Quote Originally Posted by In Utopia View Post
    JLMM-45 is what you want. It's a kit that comes with the M-26 and three filters, 1 in the unit and two spares. The filters restrict the airflow when full but 1 will last the average user months. http://www.tooltopia.com/motorguard-m45.aspx
    Not intending to jack your thread, just wondering where your getting the replacement desiccant and how do you disassemble the HF dryer?
    Aug 2012
    Utopia/Pasadena, TX
    Use a 9/16" wrench on the male pipe end, grasp the the large black end and unscrew it. The gray outer housing just pulls off.
    Remove the white felt washer, pour the desiccant into a small homemade aluminum foil pan and bake for about 20 minutes at around 200deg.
    I use a toaster oven, a gas oven creates to much moisture. You'll notice they are a lot bluer than when you bought it.
    Put your finger over the center post and fill the bowl back up, put the felt washer back, screw the top back on (hand tight) and you're good to go.
    Thanks for the instructions, where do you get replacement desiccant when the old stuff no longer regens?
    Quote Originally Posted by nick54 View Post
    Google, damn, imaging that - this is what I hate about forums, tend to make me stupid.
    Don't know if anyone else has done this or tried it, but I cooked mine the other day in a glass bowl in the microwave. 15 sec and done. Nice and dark blue. a lot cheaper on the electric bill..... Maybe there is a reason not to do this???
    Everlast PowerTig 200DX
    Everlast Supercut 50P
    Any food that is cooked in that microwave after cooking the desiccant rots your teeth! Click image for larger version.
    Powertig 250EX
    Powerplasma 50
    Cobra 2000 / Henrob O/A torch
    Jun 2012
    Hutchinson Kansas
    Shane
    I think your avatar is the perfect example of why not to cook desiccant in the microwave and then cook and eat hotdogs from the same microwave. "I cooked mine the other day in a glass bowl in the microwave. 15 sec and done"
    HA HA
    Aug 2012
    Utopia/Pasadena, TX
    Just ordered the Motorguard, getting tired of changing the small filters out.
  1. Motorguard air filter. Toilet paper???
    By 3goutdoor in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 12-31-2014, 02:08 AM
  2. Qustion About MotorGuard Air Filters
    By Gerry in forum Everlast Plasma Cutters (PAC)
    Last Post: 12-04-2012, 12:33 AM
