Results 1 to 8 of 8
Thread: PP50 arc issues
  1. Default PP50 arc issues
    When I pull the trigger it will arc then go out then re arc. Sometimes there's no arc and just the air blows through the torch. My pressure is ok and there's no moisture in the air lines what so ever, I'm running a motoguard and a secondary trap. I'm vetting tired of all the issues with the machine, can someone she'd some light on the issue.
    CMILL
    Millermatic-211
    Thermal Arc 300 GTSW
    Everlast PP50
    Where exactly is your pressure sitting and your amps?
    It is sitting at 25 amps @ 65psi
    CMILL
    Millermatic-211
    Everlast PP50
    Quote Originally Posted by millermatic View Post
    You have to adjust the pressure down when you are cutting at low amperage. Should probably be around 40-50 with a larger tip. Also I assume you are trying to maintain an arc with the 50 amp1.0 or 40 amp .9 mm nozzle? To keep the best, most stable arc, you have to use a smaller consumable. They make a 20 amp tip for this low amp operation which is .6. Otherwise arc stability can be erratic.
    Thanks for the response it, i now see the issue. Also do you know if drag tips are available for the s-45, also are there any hypertherm consumables that match the torch?
    CMILL
    Millermatic-211
    Everlast PP50
    The S-25 cons that you can buy for the small Hobart cutters in Agri Supply, (I have been told, and the part numbers match from Trafimet) will fit for the low end cuts. Yes, they do have drag tips, but the tips that come with the unit are fine for dragging up to 30 amps or so. I have done it many times...no issues.
    Since your responding rather quickly i would like to ask about the torch itself, is it a nutec or is it a trafimet? From what im seeing the cons seem to be pretty similar but im sure there are some differences.
    CMILL
    Millermatic-211
    Everlast PP50
    The nutec is a version of the trafimet, and privately labeled. Our S-45 is neither(currently) though Canada does offer the Trafimet as OEM. Several companies make the same torch based off the trafimet design. If it says s-45, the cons should fit, as well as the s 25.
  1. 225 lx issues
    By SeanMurphy265 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 04-28-2016, 01:50 AM
  2. Am I having gas issues?
    By Rodzilla in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 12-04-2015, 04:19 PM
  3. 250 EX issues
    By Skeeter in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 07-21-2015, 02:50 AM
  4. Air shutoff issues - PP50 & S45 Torch
    By cpierce18 in forum Everlast Plasma Cutters (PAC)
    Last Post: 03-12-2013, 02:16 PM
  5. 205 issues
    By roadymi in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 09-21-2009, 02:27 PM
