Results 1 to 13 of 13
Thread: Need to find a bolt....
    Default Need to find a bolt....
    I'm looking for a 5/8"-27 thread bolt to fit an old microphone I'm restoring.
    I'm wanting to make a custom stand for it so if I can find a bolt that will thread into it, I can weld the stand to that.
    PowerTig 250EX
    Power I-MIG 200
    5/8"-27 is standard mic stand thread, any boom or column will have that thread.
    I know nothing about this stuff...just redoing a Mic for my wifes rock n roll room.
    I was wanting a bolt or threaded rod so I could weld it to the stand I make.... I guess the column is the rod from the base to the mic?
    Maybe I'll go to the local music shop and see what they have
    PowerTig 250EX
    Power I-MIG 200
    Unless you want something really odd, you can probably just find an off the shelf mic stand that will work good for you. One place where you can find a lot of older style models is your local pawn shops. If you want something to attach to what you already have, you can get a short extension or a gooseneck adapter from your local music shop.
    Ok.. thanks for the help.
    I actually am wanting to make something crazy, not a typical rod and base....just not sure what yet. I think I will go to the pawn shop, didn't think of that!
    PowerTig 250EX
    Power I-MIG 200
    Sep 2011
    Middleburg Florida
    You could always buy a die or have someone with a lathe spin one out for you if you can't find the shape/material you're looking for...
    Trip
    Trip Bauer
    Former USN HT
    Everlast 200DX New Model
    Hobart Handler 125 MIG
    Van Norman #12
    Atlas 12" engine lathe
    Trip
    Thinking of something artsy!?! Casting something or ???
    Not saying I can do these but this is what I like....
    http://www.google.com/imgres?q=custo...76&tx=58&ty=92
    http://www.google.com/imgres?q=custo...9,r:0,s:0,i:73
    PowerTig 250EX
    Power I-MIG 200
    Probably a good idea to get a regular stand to use parts off of, and a good jumping off point. There are literally dozens of styles but most fall into folding legs, or a weighted base, then with or without a mini boom. Another option is that there are podium mounts that are made to screw down, then mount a gooseneck to.
    Sep 2011
    Middleburg Florida
    Neat stuff! I was about 5 minutes from making a bolt the other day, needed one, didn't have a way to get to the hardware store and I didn't have the proper die for the size/pitch. Certainly easier to buy one, but it's nice having a lathe for those times you can't find one in the size, material, etc. you need.
    Trip Bauer
    Former USN HT
    Van Norman #12
    I'm wanting a weighted base. Might be easier for me to get a cheap stand, use the pole and make my own base to match the mic.
    Maybe just a little easier than casting something that I like.....
    This is the microphone I'm restoring...
    http://www.google.com/imgres?q=turne...r:11,s:0,i:107
    PowerTig 250EX
    Power I-MIG 200
    A lot of stands have a nice spun aluminum or other cover over the base with a rough cast iron underneath for weight. Like lamps, they often use long threads on the column to hold everything together. So you could make a new base cover to match your design, then use the stock weight under it. The base thread is 7/8"-27 for floor stands, but the same 5/8"-27 for desk stands. Brand new mic stands are dirt cheap, but some of the older ones bring some money as collectors items.
    Good idea... I was wondering how I would get some weight to it.
    I think the first thing is to get a stand. Found one online for $15 but the shipping was the same so I can probably find one locally for $30
    PowerTig 250EX
    Power I-MIG 200
    I bought a mic stand locally for $25. After I got it home and put it in the corner with her guitar and amp, you really didn't see the base of the stand too much so I'm just gonna leave it like it is.
    Here's some pics of the Mic I restored and it's also on EBAY if you want to buy it!!
    I found a Shure 55sh cheap and it's a more Iconic microphone
    PowerTig 250EX
    Power I-MIG 200
  1. HF Ground Bolt?
    By Jacobelps in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 09-08-2016, 04:38 PM
  2. Steering 14 Bolt
    By GFab70 in forum Off Road Fabrication
    Last Post: 12-04-2015, 03:50 PM
  3. Removing a broken bolt - steering box
    By seanm in forum Welding Repairs
    Last Post: 08-14-2013, 06:43 AM
  4. Bolt removal questions.
    Last Post: 09-14-2012, 12:16 AM
  5. Project #10 From Jason: Stripped Lug Bolt.
    By Jason in forum Personal Projects (no welder required)
    Last Post: 03-24-2012, 09:29 PM
