Results 1 to 20 of 30
Thread: Super cut 50 plasma cutter
  1. Default Super cut 50 plasma cutter
    I just bought a plasma supercut 50 with the upgrade 60a torch, I seem to be going through the ceramic tips is this normal? I'm new to forum's so I hope I done this right.
    No the ceramic cups do not usually give problems and last a while, if they are properly used and stored. Can you give specifics on what is going on?
    I'm working in cold weather, and I'm cutting 1/8 in angle.
    Should I maintain my desired pressure while air is flowing or should I set it and then cut?
    Thanks as usual,
    I Love Plasma
    Flowing,
    I will post a video(s?) in the next day or so so that people can get the idea. It will be on the PP60, but will give you a good idea of how the unit cuts, and is operated.
    Question
    Hi All,
    We've been trying to build a skidloader bucket.
    Many buckets have a replaceable cutting edge.
    When we were plasma-ing out the angled portion cutting edge for the bucket we had the piece standing on edge, and we torched it, holding the wand at an angle, rubbing the tip on straight board for a guide. Does anyone have good ideas about how to cut this out? It turned out fairly good, but could have been better.
    I've attached a picture. I'm hoping it works.
Name:	Plasma VS Cutting Edge.JPG
    Your use of a guide is right on. The limit is the thickness of the cut and the fact you are not cutting 90 degrees to the surface. Try a slower cutting speed.
    Wayne
    Thanks a lot Wayne.
    How would you go about cutting such a hard to do cut?
    What you are doing there is an art form. It takes skill and practice to draw a torch that distance with or without a guide.
    There are limits to plasma. This is one of those borderline cases if the angle you cut was steep. A 45 degree bevel on 1/2 inch would equal about 3/4 of an inch deep cut. If it is steeper, it would be a deeper cut. It could be done on a track torch machine and would make a perfect bevel. However, hand operation is difficult and what you did is about as good as it could be rigged. A jig could be made to work, but I doubt it would be time efficient though perhaps the jig could be reused or adapted to other operations.
    Now with that said, my recommendation, based of having done this myself before, is to use OxyFuel for this, since even the smallest torch will cut a long steep angle like this at a faster speed. I have both oxyfuel and plasma in my arsenal. I use both, though the plasma gets 80% of the work these days. An Oxyfuel rig will always save you in a pinch. Also, a plasma is no good at heating, welding, or brazing.
    Jan 2010
    Chugiak , Alaska
    Hi, I do a lot of “hack” fabricating, I mean “expeditious field repairs” . And have used plasma a lot for the kind of stuff I think your doing. I hate to push others products but one of the best investments I think I’ve ever made in my plasma set up was a circle cutting kit I happen to have one made by/for Thermal Dynamic, it was uber expensive, but I use it A LOT, now your probably wondering why that has anything to do with slicing off the cutting edge, or is it the bucket side? The kit has a bunch of guides and rods in it that you can put together in several ways and a magnet and suction cup base for the circle cutter, but has these cool guide wheels and a collect that fits over the torch head, there are several adaptors for different types of torches. Anyway enough of the unauthorized sales pitch.. What I do with this and most stuff with plate or darn near anything I need a strait cut on is use the wheels or if it’s a rough surface the angled point guide, against a piece of flat strap clamped or even tacked to the work, at a distance from the intended cut (about 1.75”) and guide the wheels down the edge of the strap. You may be able to do pretty much the same thing with the guide ring on the torch as well. As far as the angle you can set the wheels at different heights to maintain a consistent angle, I’m going to try to attach a picture. Hope this helps.
    Ray
    ____
    Ray
    support@everlastalaska.com
    www.everlastalaska.com
    877-755-9353 X207
    Thumbs up
    Thanx Ray,
    I'm considering Mark's track idea. There's a potential that I'll need to cut quite a few of these out these out.
    Everlast sells a metal guide wheel set, I think it's Brass or a similar product.
    Please take a look at the pics I posted down there on my initial post. I'm cutting a bevel on the edge of the flat stock to create a cutting edge for a bucket.
    Hey, welcome to one of the greatest forums around. I appreciate that your first post is posted to help me out.
    BTW,Mark, We've got a OxyAcetylene torch but the refill prices are much more than a couple sets of 60A tips. I like Ur idea about that track system.
    Thanx as usual,
    I LOVE Plasma
    Last edited by I_Love_Plasma; 02-18-2010 at 09:36 PM. Reason: Added verbage, instead of posting another letter.
    Jan 2010
    Chugiak , Alaska
    Thanks, didn't intend to muddy the waters, the track sounds like the way to go , here is what I was talking about on the angle. I think it was Wayne that said somthing about a 45 deg. angle, my recomendation would be to use a 20 -30 deg. angle, but that depends a lot on what you're digging I guess. I assume you're not using an actual hardened cutting edge?
    ____
    Ray
    877-755-9353 X207
    Quote Originally Posted by WAYNESWORLD View Post
    Wayne
    I bought one of those wheel guides and found it works well, except I have a hard time seeing my lines on the metal with my mask set to 9. Any ideas on how to make the shape outline easier to see with the mask down? Many thanks.
    For the larger plasmas, we have wheel guides like the one pictured.
    Rink,
    Generally, No more than a shade 7 us required for plasma cutting. I recommend a 5 unless its over 60 amps. The arc is not usually as visible and partially obstructed so a darker lens is not required.
    With that said, I use a pair of Nemesis cutting glasses instead of the cutting shield or welding helmet. Its adequate and freeing.
    Default Eye protection for plasma cutting
    Thanks for your response. I went over to the Central Welding Supply site.
    Here's what they recommend for plasma:
    Current Level
    in Amps Minimum Shade Number
    Below 20 #4
    20-40 #5
    40-60 #6
    60-80 #8
    I'm still looking for a clever way to protect my eyes and see my drawn
    lines for the cut.
    Thanks again.
    Jerry
    Try yellow or bright white lines with very little back ground light.
    Wayne
    Wayne is right.
    I use a Markal paint ball valve action marker. Yellow or white shows up very well. Soap stone is not good for this. A marker will last a long time, not as long as a piece of soap stone and its much pricier, but the marker won't break into pieces the first time it hits the floor either.
  18. Default
    On one of the welding supply stores I saw a marking pen that was said to not burn away like soap stone or the other markers. Wish I had link but have been wanting to try one. I also found that a sharp awl dawn down your line to work fairly well, at least better then soap stone. Of course the awl works better on slightly rusted or steel with mill scale.
    The Markal has this type pen.
    Post
    Quote Originally Posted by rinktumbody View Post
    Yeah just get a set of two 500 watt halogen work lights that drywallers use. And Black Board chalk works good, cheap too. Makes every thing light up. I use them all the time.
  1. Power Plasma 50 plasma cutter....
    Last Post: 07-20-2012, 01:58 PM
  2. Problems with plasma cutter
    By Kodiak in forum Everlast Plasma Cutters (PAC)
    Last Post: 04-11-2012, 08:19 PM
  3. Any suggestions for Super 160p to get the plasma cutter to work better?
    By Spike in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 02-16-2012, 04:46 AM
  4. Super 200P - Plasma Cutter Will not Ignite
    By captbroberts in forum Everlast Plasma Cutters (PAC)
    Last Post: 02-02-2010, 12:39 PM
  5. Plasma Cutting Settings Super 200P
    By CapnMilo in forum General Welder Questions
    Last Post: 02-05-2009, 08:48 PM
